pinion speedi sleeve #852262
11/12/10 10:53 PM
11/12/10 10:53 PM
mn.
P
prairiechicken1 Offline OP
P
mn.
Dose anyone know if the speedi sleeve listed for 8.75 pinion case 741-742 would fit a 489? I can't seem to find a listing for a 489 case.Thanks as always for the help!!
Re: pinion speedi sleeve [Re: prairiechicken1] #852263
11/12/10 11:14 PM
11/12/10 11:14 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would think if they all use the same seal, that the sleeve should be the same also, no?
Re: pinion speedi sleeve [Re: buildanother] #852264
11/13/10 02:26 AM
11/13/10 02:26 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
You can use a normal seal. All you have to do is tap it in part way so the seal lip does not ride on the worn area of the yoke. I have one that has been running like that for years!
