e body rear suspension #852193
11/12/10 09:12 PM
11/12/10 09:12 PM
southwest pa
bodyworks racing Offline OP
southwest pa
a good freind of mine just bought an e body cuda i converted him from a chebby the car has a ladder bar set up with a dana 60 and springs the springs seem to be floating ie just holding the body up anybody ever see a set up like that also would you go with just springs or go coil overs with the ladder bar never saw a set up like this car will be pro street with limited strip duty car just came home will try and post pictures this weekend suggestions???
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: e body rear suspension [Re: bodyworks racing] #852194
11/12/10 09:55 PM
11/12/10 09:55 PM
If you use leaf springs with ladder basr you have to use either a slider or a floater set up on the rear end housing due to the unequal length(usually) of the front half of the leaf springs compared to the ladder bar lengths Google rear end floaters and sliders for picture and explanation of the two
Re: e body rear suspension [Re: bodyworks racing] #852195
11/12/10 09:56 PM
11/12/10 09:56 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
yes. that is how its done with leaf springs.
springs just hold the car up. so be it a leaf or coil it really doesnt matter. leafs are probably heavier though
Re: e body rear suspension [Re: sixpackgut] #852196
11/13/10 08:51 PM
11/13/10 08:51 PM
southwest pa
southwest pa
thanks to you both for the reply we googled it cab and it shed a lot of light on this type of setup look like all we are going to have to do is make a good top shock mount we dont think the stock one will hold up will post pics of mount when we get it fabed up thanks again
