Early A body, A or b,rb motor?
#851880
11/12/10 03:53 PM
11/12/10 03:53 PM
Posts: 10,035 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have another 65 Dart body, am considering which way to go, A or B motor for a street car. I have many B motor parts, virtually every thing but rods and pistons, rings and bearings. Ditto on the trans and drive shaft. For an A motor I have very little. A small Holley, a high volume fuel pump, and possibly a good radiator. I fabricate suspension, build headers If I have to, most any thing. Looks like I will have to convert to coil overs and build headers if I go B motor, unless someone has a better Idea. The B motor pan I have is a 10 qt dragster style, so the conversion to coil overs and a rack would help there. I would appreciate a rundown of anyones' B motor early A, as well as small block early A setups. The small block is appealing but as mentioned I have very little on hand to start with.
