front shocks #851361
11/11/10 07:05 PM
11/11/10 07:05 PM
W.Va
fowl play Offline OP
W.Va
what are you guys running on the front of your race cars? i've got a smallblock a body race car. looking for thing to change for consistancy. running old 90/10 shocks. what brand and are they adjustable or not? this a 2800lb 10.50 car. coil over ladder bar rear susp. 6 cyl. torsion bar front. thanks
Re: front shocks [Re: fowl play] #851362
11/11/10 07:13 PM
11/11/10 07:13 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Santhuff double adjustable coil overs
home of the
Sox and Martin Hemi Duster
Re: front shocks [Re: fowl play] #851363
11/11/10 07:14 PM
11/11/10 07:14 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I'm using Cal Trac 90/10 non adjustable. I like them so far. They have way less dampening than the CE shocks. The car is fun to drive but I can't say that it's faster or hooks up better. If you want more front end rise, and don't want to spend a lot of money, they are the shock for you.
Re: front shocks [Re: fowl play] #851364
11/12/10 12:10 AM
11/12/10 12:10 AM
Look at using a set of the koni SPA1 front shocks I've got a BB duster with ladder bars and coil overs using a diagonal length that runs mid to low tens on ET Street Radails, those front shocks are the best I've treid so far, not the most expensive or the cheapest but the best so far
Re: front shocks [Re: Cab_Burge] #851365
11/12/10 12:54 PM
11/12/10 12:54 PM
HOUSTON,TEXAS
FIREGUY12 Offline
FIREGUY12  Offline
HOUSTON,TEXAS
santhuff shocks all the way.
Re: front shocks [Re: FIREGUY12] #851366
11/12/10 09:24 PM
11/12/10 09:24 PM
southwest pa
bodyworks racing Offline
southwest pa
calvert 90/10s for me 68 rr 11.50 my 60 ft improved from 1.59 to 1.55 with them not bad for a 150 dollar shock
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: front shocks [Re: bodyworks racing] #851367
11/13/10 05:02 AM
11/13/10 05:02 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
calvert's here too. i don't care for them on the street though, i usually put the comps back on for cruising around.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
