Re: Whats easier? BB or SB swap into /6 72 Dart [Re: sharpie] #85073
07/07/08 04:58 PM
07/07/08 04:58 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Like I said,im just kicking the idea around. Sorta like
pipe dreamin". Figured the sb would be easier,since A bodies were optioned with them . Thanks for all the perspectives on the subject.
They were optioned with big blocks, too.
not after 69
That's completely irrelevant as the engine bay did not change.
You also don't have to buy expensive headers or any of the other expensive parts. If you don't mind a little fabrication and you're not trying to grab every last bit of horsepower the car can bebuilt rather cheaply.
Outside of the purchase price of the car and body/paint/interior I'll have the 440/727/3.23SG 8-3/4 in my Barracuda convertible for well under $2k, probably under $1k. Yes, the 440 was basically free and I can build the 727 for about $100. I can also build the $20 73-76 k-member into a Direct Connection unit for very little.
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: SPWC] #85074
07/07/08 05:01 PM
07/07/08 05:01 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Well now. from a "working on" stand point a small block is much easier to deal with. I had a 68 w/ a 383 butttt it had no fender wells I could pretty muh stand up in the engine bay. My freind has a 69 500 wedge fender wells..it is a MoFo to work on. My 72 w/ a 340 was a piece of cake.
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: Jim_Lusk] #85075
07/07/08 05:03 PM
07/07/08 05:03 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'd go with a smallblock.
Even if you wanted more power you could stroke the smallblock out to 400+ cubes. A 408/416 smallblock in an a-body will go as fast as you ever need to especially on the street.
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: Jim_Lusk] #85076
07/07/08 05:08 PM
07/07/08 05:08 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Handling isn't hard. It's a myth based on 60s tires.
Well I see a big heap of body roll there and a couple cones knocked over, does look like fun though
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: HotRodDave] #85077
07/07/08 05:35 PM
07/07/08 05:35 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Nope, no cones knocked over. Those are the direction cones. And, that was one tight corner. There would have been the same amount of roll with a small block. We also had a lot of grip with the tires.......
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: stumpy] #85078
07/07/08 05:46 PM
07/07/08 05:46 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
I've built both and for all round ease and fun factor just build a small block. You will save a bunch of grief and cash. You would be able to keep ac ps and original shifter on the column and exhaust is available at a reasonable price. The big block has an awe factor but it is a load of extra work and extra costs. You won't be able to use a/c. You will have to add a floor shifter and find headers that will need reworking. BB is very hard to work on in an A body. You could always put a cam, headers and 4bbl on the slanty and have some fun.
"You won't be able to use a/c"
My S6 a/c and hoses, radiator hose, all wiring, PS pump, and throttle cable fit perfectly...see pic
Russ:)
BigBlock 74 Swinger
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: bb74swngr] #85079
07/07/08 06:21 PM
07/07/08 06:21 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Here's another with the AC hooked up, but we never charged the system before selling the car.
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: JohnRR] #85080
07/07/08 06:30 PM
07/07/08 06:30 PM
NE Oklahoma
71valiant Offline
71valiant  Offline
NE Oklahoma
you likely won't be using the column shifter stuff with a BB. Might get away with it with a SB.
not with a 727 , the Z bar for the shift linkage is very hard to find
I swapped in a 360/727 in my 71 valiant. I used the column shifter and it works perfect. I had to do alittle bit of fabricating and adjusting. It wasent a big deal.
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: 71valiant] #85081
07/07/08 08:33 PM
07/07/08 08:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
It's a 3 speed manual car...
Still think the column shift will work?
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: RobX4406] #85082
07/07/08 09:47 PM
07/07/08 09:47 PM
NE Oklahoma
71valiant Offline
71valiant  Offline
NE Oklahoma
Actually I knew a guy with a 66 dodge pickup that was a 3 speed on the column 318 truck. He dropped in a 727/383BB and used the 3 speed on the column shifter. He disabled the part that made it slip back in the 1st and reverse side so it just slid up and down on the 2nd and 3rd back side. Ive seen it, believe it or not.
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: SPWC] #85083
07/07/08 10:03 PM
07/07/08 10:03 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
I'll let you know pretty soon on the RB install, I'm guessing my 500 inch RB will likely be tough to work on, but probably no worse than the 355/angle plug small block Pro Street Vega I had back in the early 80's. I drilled holes in the area where the bellhousing bolts were just to pull the tranny a little more easily!
If I'd've known it was gonna end up in an a-body, I probably would've built a 416 instaed....
Re: Whats easier? BB or SB swap into /6 72 Dart [Re: 300by500] #85084
07/07/08 11:48 PM
07/07/08 11:48 PM
440Demon Offline
440Demon  Offline
Currently running a 440 4 speed A Body with the 2" TTI set up. Not really that bad to tweak on but there are a ton of tight spots. If you haven't wrenched on these cars a bunch - go with a stout small block. They can make a ton of power, are well balanced (compare to a BB) and most all of the parts you need will be relatively cheap.
