Re: "over rust" liners for the WHOLE underside of my truck
[Re: The70RTChallenge]
#850496
11/10/10 03:42 PM
11/10/10 03:42 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
In the same paragraph you used the words: "rust", "underside", "no lift", "no prep", "quick", and "easy". Then, the solution is simple: Pray for a miracle. You're welcome.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#850497
11/10/10 03:52 PM
11/10/10 03:52 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
This is something that everyone here would like to find. AND if anyone has they aren't sharing.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: crlush]
#850500
11/11/10 12:12 AM
11/11/10 12:12 AM
DaytonaTurbo
Manitoba, Canada
por-15 is your best bet
POR-15 doesn't stick to a properly prepped surface, nevermind one just blasted at the car wash.
#850504
11/11/10 05:04 PM
11/11/10 05:04 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Get one from Texas, NM, AZ, CA, or OK. Fly in and drive it home. Sell what you've got.
My 92 D250 is packing 273,000 miles and doesn't have a spot of rust on the body. It's been in Texas all it's life other than my road trips to 34 other states.
#850508
11/12/10 04:14 PM
11/12/10 04:14 PM
feets
Senior Management
Senior Management
Irving, TX
If you take a wire wheel to the truck you're going to need something GOOD to cover that bare metal.
