Intermittent miss #850225
11/09/10 10:11 PM
11/09/10 10:11 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Could a header leak at the motor cause an intermittent miss.
Re: Intermittent miss [Re: chargers777] #850226
11/09/10 10:49 PM
11/09/10 10:49 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Can't say I've ever heard that causing a miss. I'd check the wires.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Intermittent miss [Re: Magnumguy] #850227
11/09/10 11:44 PM
11/09/10 11:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Leaky header can cause a lean condition but I would really check for a bad plug wire or fouled plug.
Re: Intermittent miss [Re: MoparforLife] #850228
11/09/10 11:51 PM
11/09/10 11:51 PM
Hr up from KCK
451 D*O*D*G*E Offline
Hr up from KCK
You sure its a actual miss?I added "Heat" one time cause couldnt find nothing wrong..it fixed the ood unsteadiess..water in gas..also the best thing to do is pop the hood at night and look for any grounding plug wires.sometimes its not even at the head it could be between two wires that lay on each other.
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
