Page 10 of 11 1 2 8 9 10 11
Re: True Street car ET's [Re: Thumperdart] #849853
06/07/14 12:47 AM
06/07/14 12:47 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
100% NA.
fact is could be faster as only have 520 net cam lift and 440+0.055 ci.A little weight reduction wouldn't hurt either .
Car is only legal to 11.00 - no roll cage , fire suit , unlimited licence , tech etc
oh I drive it every day to work also
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: True Street car ET's [Re: 68LAR] #849854
06/07/14 01:21 AM
06/07/14 01:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have to wonder how many of these "street cars" that are running 10's and low 11's are running a nitrous kit to get there?
The only power adder I have is my right.... and left foot!!!!!
Same here as I have never even owned a car with a power adder. But I have to live within my budget and I cant afford to blow up many engines so I like to stick to N/A like many here. Just put about 50 miles on my 63 tonight driving to a cruise spot. I do enjoy that I do drive my car to the track and race it just as I drive it on the street capped up on pump. Actually I have never uncapped my 63 or had race gas in it and thats ok with me as I am getting old and dont want to slide under the car at the track to uncap it and I cant afford race gas anyway. Ron
Re: True Street car ET's [Re: 383man] #849855
06/07/14 05:39 PM
06/07/14 05:39 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
My Satellite has run a best of 10.60 @ 127.... With a pump gas 440. I working on trying to get it to hook.... I can't launch at over 2000 rpm on the converter or it will just spin.... Don't get me wrong I wouldn't drive this thing down the interstate but it still wears everything it needs to be a legal street car and I take it to cruise ins and run errands with it.....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: True Street car ET's [Re: QTR MILR] #849856
06/07/14 06:08 PM
06/07/14 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I havent run a true street car on the track in over
20 years... couldnt afford to bust it up.. now I built
the Rampage but it hasnt been on the track YET.. but
based on math it should run 9.80.. but I only want
10.0 to 10.1.. I'm hoping to get out in a week or so
to start dialing things in... I worked on the carb the
other day but I went a touch lean for cruise.. seen
the coolant temp raise 5* in the cooler evening temps..
was great in the heat of the day.. so I'll fatten it
up some then start some WOT testing at the track...
so till then its all just math and I'll let you know
how it does on the track
Re: True Street car ET's [Re: MR_P_BODY] #849857
06/07/14 09:16 PM
06/07/14 09:16 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
Just drove mine to the local 1/8 mile track last night, which is only about 20 miles each way. I'm sorting out a new combo and only hooked on one pass (where I took off in 2nd gear). Went 6.42 @ 113.47 with only a 1.602 60' time. 100% factory interior, drag radials, exhaust, all steel 70 Charger. Not the quickest thing out there, but not many cars around here drive to and from the track.
Re: True Street car ET's [Re: Charger453] #849858
06/07/14 10:32 PM
06/07/14 10:32 PM
Mo.
racerx Offline
racerx  Offline
Mo.
That's pretty good MPH in the 1/8 work on those 60's and all is Good.
Re: True Street car ET's [Re: racerx] #849859
06/07/14 10:36 PM
06/07/14 10:36 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
mine is a little street car small block lol
Re: True Street car ET's [Re: racerx] #849860
06/07/14 10:41 PM
06/07/14 10:41 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
It has potential. I did leave out that it has a Procharger. The car was previously a N/A car that went 6.71 @ 101.5 with a 1.44 60' All I did was swap head gaskets and the cam when I threw on the blower. I'm still tuning as last night was the first outing with the setup, but I see 6.1X @ 115 as a real possibility. I need to learn to read plugs better but my wideband is saying I'm pretty rich. I'm only running 8-9 PSI as well.
Re: True Street car ET's [Re: Charger453] #849861
06/09/14 02:25 PM
06/09/14 02:25 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I drove my Barracuda to the track last Friday for the Good Guys All American Nationals at Lucas Oil Raceway, entered the Street Machine 1 category (11.99 and quicker class), laid down a string of 10.79's and WON THE RACE!!....and drove the car home again...left a lot of folks with their jaws hanging open.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: True Street car ET's [Re: FlyFish] #849862
06/09/14 03:21 PM
06/09/14 03:21 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I love that kind of stuff!! I went to TNT at a local track Friday night to try to get my car to 60ft. better. I popped the hood to let it cool off and I get people checking it out saying " That still has all the headlights and wiring in it". I need one of those sun shields at the top of the window that says "This is a Street Car".....
Scott
Re: True Street car ET's [Re: QTR MILR] #849863
06/09/14 05:28 PM
06/09/14 05:28 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
My 'Cuda runs mid-10's thru full length exhaust, 3800lbs on the motor,91 octane pump gas,DOT tires,gets between 12-13mpg. I have driven it on the Car Craft Anti Tour twice, both were between 350-400 miles each way,have driven it on MANY other drives, cruises or just cause I felt like driving it to breakfast with friends 40 miles away.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: True Street car ET's [Re: johnnycuda] #849864
06/09/14 07:08 PM
06/09/14 07:08 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
You and that 383man have my utmost respect. Freakin' COOL to drive your 10 second car any day, anywhere you want to!
Is your car Sublime, by chance?
Re: True Street car ET's [Re: cudadoug] #849865
06/09/14 08:15 PM
06/09/14 08:15 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mine is not a car but I drive it on the street. I have been driving my D50 to the track and running it. It is a 40 mile round trip and the best ET so far has been 6.29, 109 with a 1.33 60ft. It is small block on 93 pump gas, drag radials, mufflers and 2950 lbs. I just put a bigger carb on it this weekend and hope to go faster this Friday night.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: True Street car ET's [Re: FlyFish] #849866
06/09/14 10:52 PM
06/09/14 10:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats cool. Kinda reminds me of my last time at the track as I ran 10.76 three passes in a row and still lost in the second round running a 10.76 on a 10.75 dail. I was kinda very pleased and surprised as here a street car I drove 45 miles to the track with just SS springs and it was more consisdent then I thought it would be. But I kept thinking I would run a new best and it just wanted to run 10.76 all the time. Oh I lost to my brother because I hit an .078 lite to his .012. Ron
Re: True Street car ET's [Re: cudadoug] #849867
06/09/14 10:56 PM
06/09/14 10:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thank you for the kind words. Ron
Re: True Street car ET's [Re: 383man] #849868
06/10/14 12:03 PM
06/10/14 12:03 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Lot's of nice and fast street cars!
Re: True Street car ET's [Re: cudadoug] #849869
06/10/14 02:55 PM
06/10/14 02:55 PM
johnnycuda Offline
johnnycuda  Offline
Hey cudadoug, yep,my 'Cuda is Sublime with black 440 hockey sticks, has a 4" cowl hood, Weld Draglites,had a couple pics of it in the Sept 2011 issue of Car Craft.
Re: True Street car ET's [Re: johnnycuda] #849870
06/11/14 12:55 AM
06/11/14 12:55 AM
cudadoug Offline
cudadoug  Offline
Yep, saw those pics! I HOPEFULLY can come down and run the Anti Tour in 2015. Looks like big fun.
Any pics of that bad-azz Cuda you care to post, we'd gladly look!
Re: True Street car ET's [Re: cudadoug] #849871
06/11/14 03:31 PM
06/11/14 03:31 PM
johnnycuda Offline
johnnycuda  Offline
Hey Doug, the Anti Tour this year is tentatively going to Escondido on Friday ,July 25th then to grudge night at Barona the next day, haven't heard a definite plan.
I've never been able to get pics onto this site as I'm not great with computers and my old laptop had issues, maybe I can get my new laptop to get it done.
Re: True Street car ET's [Re: johnnycuda] #849872
06/19/14 04:57 PM
06/19/14 04:57 PM
SO. FLA
W
W2WHO Offline
W2WHO  Offline
W
SO. FLA
W5 HEADED 416 AT 3300LBS. BEST 1.33 60FT 9.93 ALL MOTOR
RADIALS AND MUFFLERS
http://youtu.be/9qFjHOmLoA4
