True Street car ET's
#849673
11/09/10 05:40 PM
11/09/10 05:40 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Just curious.. What kind of ET's are you guys running that are true street cars. Let me define "street cars" for this post. Functional headlights/tail lights Inspection sticker and can pass inspection for thier state No lexan front windshields or side glass Pump gas (E-85 ok) Tagged and Insured Full interior Drive it the way you run it! Im not trying to eliminate people/cars. I just want to see what is out there. Not a race car that can be driven on the street with a few changes, etc. ![](/ubbthreads/images/graemlins/beer.gif)
Re: True Street car ET's
[Re: TheOtherDodge]
#849674
11/09/10 05:45 PM
11/09/10 05:45 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
When I drove my Duster on the street, full exhaust, street tires, belt driven water pump and all with a W2 340 I could just lower the tire pressure and run 11.70's in the Florida heat.
[Re: TheOtherDodge]
#849675
11/09/10 05:47 PM
11/09/10 05:47 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
9.50s at 140 mph on motor. I race it the same way I drive it on the street w/ the exception of the mufflers. It's been 9.50s w/ the race bullet mufflers. I street drive it w/ Flowmasters...been 9.60s w/ them on it.
[Re: Jeff_383]
#849679
11/09/10 06:04 PM
11/09/10 06:04 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
11.57 @ 117.86 mph so far. (Ran 11.64 @ 118.26 on a previous pass the same day.) This is in 100% street legal trim. Air cleaner, full exhaust back to the rear valance, and with the car seat still installed in the back seat. The way we race it is the same way you see us driving the car down the highway or around to the local cruise nights/shows. Cast crank 440 w/ 906 heads. ![](/ubbthreads/images/graemlins/blush.gif) Edit: No power adders of any kind either.
[Re: Blues_Cuda]
#849680
11/09/10 06:20 PM
11/09/10 06:20 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
10.91 so far in stupid heat. Full interior ,heater, wipers, Et streets. No spray street car. ![](/ubbthreads/images/graemlins/thumbs.gif)
6.50 @105.26
[Re: TheOtherDodge]
#849682
11/09/10 06:29 PM
11/09/10 06:29 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
11.0 at 123 in mid 90s heat, 2000+ ft DA
Hope to get out at least one more time before it gets too cold or the tracks close, it should be good for 10s in the cooler weather we have now.
No trailer here yet, so wherever it needs to go it goes under it's own power.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#849686
11/09/10 06:57 PM
11/09/10 06:57 PM
Posts: 198 Gainesville Fl
mphsmitch
Gainesville Fl
Mine runs 12.40s @ 107mph 10.92 @ 122.mph on 175 shot 275/60 drag radials,3500lbs with me in it.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
[Re: joshking440]
#849688
11/09/10 07:52 PM
11/09/10 07:52 PM
Posts: 9,883 MI, usa
dvw
MI, usa
I've driven mine from N.W. Detroit to Columbus a couple of times. 11.01@124 best. Last time out at the Classic at Norwalk 11.11@121. Stock suspension with a couple of extra leaves and adjustable rear shocks. 3875 w/me in it. A.C. stuff is still in the dash,no electric water pump. 340+.030" W/ a worn out diesel blower mounted on a 4 barrel intake. Doug
[Re: mopar dave]
#849690
11/09/10 07:58 PM
11/09/10 07:58 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
consistant 10.50's with mufflers and dot radials. even pulls the wheels off the foot brake. 10.6:1 compression 408.
Not to hijack, but I'd really like to know the rest of that motor/converter/gear combo...
What's it weigh??
