Re: True Street car ET's
[Re: Thumperdart]
#849853
06/07/14 12:47 AM
06/07/14 12:47 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
100% NA. fact is could be faster as only have 520 net cam lift and 440+0.055 ci.A little weight reduction wouldn't hurt either . ![](/ubbthreads/images/graemlins/beer.gif) Car is only legal to 11.00 - no roll cage , fire suit , unlimited licence , tech etc oh I drive it every day to work also Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 68LAR]
#849854
06/07/14 01:21 AM
06/07/14 01:21 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have to wonder how many of these "street cars" that are running 10's and low 11's are running a nitrous kit to get there?
The only power adder I have is my right.... and left foot!!!!!
Same here as I have never even owned a car with a power adder. But I have to live within my budget and I cant afford to blow up many engines so I like to stick to N/A like many here. Just put about 50 miles on my 63 tonight driving to a cruise spot. I do enjoy that I do drive my car to the track and race it just as I drive it on the street capped up on pump. Actually I have never uncapped my 63 or had race gas in it and thats ok with me as I am getting old and dont want to slide under the car at the track to uncap it and I cant afford race gas anyway. Ron
[Re: QTR MILR]
#849856
06/07/14 06:08 PM
06/07/14 06:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I havent run a true street car on the track in over 20 years... couldnt afford to bust it up.. now I built the Rampage but it hasnt been on the track YET.. but based on math it should run 9.80.. but I only want 10.0 to 10.1.. I'm hoping to get out in a week or so to start dialing things in... I worked on the carb the other day but I went a touch lean for cruise.. seen the coolant temp raise 5* in the cooler evening temps.. was great in the heat of the day.. so I'll fatten it up some then start some WOT testing at the track... so till then its all just math and I'll let you know how it does on the track ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Charger453]
#849858
06/07/14 10:32 PM
06/07/14 10:32 PM
Posts: 4,085 Mo.
racerx
Mo.
Just drove mine to the local 1/8 mile track last night, which is only about 20 miles each way. I'm sorting out a new combo and only hooked on one pass (where I took off in 2nd gear). Went 6.42 @ 113.47 with only a 1.602 60' time. 100% factory interior, drag radials, exhaust, all steel 70 Charger. Not the quickest thing out there, but not many cars around here drive to and from the track.
That's pretty good MPH in the 1/8 work on those 60's and all is Good.
[Re: racerx]
#849860
06/07/14 10:41 PM
06/07/14 10:41 PM
Posts: 867 Bellevue, NE
Charger453
Bellevue, NE
It has potential. I did leave out that it has a Procharger. The car was previously a N/A car that went 6.71 @ 101.5 with a 1.44 60' All I did was swap head gaskets and the cam when I threw on the blower. I'm still tuning as last night was the first outing with the setup, but I see 6.1X @ 115 as a real possibility. I need to learn to read plugs better but my wideband is saying I'm pretty rich. I'm only running 8-9 PSI as well.
[Re: QTR MILR]
#849863
06/09/14 05:28 PM
06/09/14 05:28 PM
Posts: 861 lancaster,california
johnnycuda
My 'Cuda runs mid-10's thru full length exhaust, 3800lbs on the motor,91 octane pump gas,DOT tires,gets between 12-13mpg. I have driven it on the Car Craft Anti Tour twice, both were between 350-400 miles each way,have driven it on MANY other drives, cruises or just cause I felt like driving it to breakfast with friends 40 miles away.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: johnnycuda]
#849864
06/09/14 07:08 PM
06/09/14 07:08 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
You and that 383man have my utmost respect. Freakin' COOL to drive your 10 second car any day, anywhere you want to!
Is your car Sublime, by chance?
[Re: cudadoug]
#849865
06/09/14 08:15 PM
06/09/14 08:15 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mine is not a car but I drive it on the street. I have been driving my D50 to the track and running it. It is a 40 mile round trip and the best ET so far has been 6.29, 109 with a 1.33 60ft. It is small block on 93 pump gas, drag radials, mufflers and 2950 lbs. I just put a bigger carb on it this weekend and hope to go faster this Friday night.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: cudadoug]
#849867
06/09/14 10:56 PM
06/09/14 10:56 PM
383man
Balt. Md
Thank you for the kind words. Ron
[Re: cudadoug]
#849869
06/10/14 02:55 PM
06/10/14 02:55 PM
johnnycuda
Hey cudadoug, yep,my 'Cuda is Sublime with black 440 hockey sticks, has a 4" cowl hood, Weld Draglites,had a couple pics of it in the Sept 2011 issue of Car Craft. Quote:
[Re: cudadoug]
#849871
06/11/14 03:31 PM
06/11/14 03:31 PM
johnnycuda
Hey Doug, the Anti Tour this year is tentatively going to Escondido on Friday ,July 25th then to grudge night at Barona the next day, haven't heard a definite plan. I've never been able to get pics onto this site as I'm not great with computers and my old laptop had issues, maybe I can get my new laptop to get it done.
