Small block oil pump gasket? #849000
11/08/10 03:58 PM
11/08/10 03:58 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Do I need a small block oil pump gasket or can it go directly metal to metal?
Re: Small block oil pump gasket? [Re: RV2] #849001
11/08/10 04:11 PM
11/08/10 04:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Machined fit. Some overhaul kits come with one but they didn't have one from the factory. I don't loose any sleep over it.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Small block oil pump gasket? [Re: RV2] #849002
11/09/10 02:44 AM
11/09/10 02:44 AM
RoadRaceDart Offline
I like to clean the pump and cap mating surfaces and use a little blue locktite to reduce leakage. A friend had the gasket blow out so doesn't like them. While you're in there check the oil pump to main cap for passage alignment. you might be surprised at how bad it is.
Joshua
Re: Small block oil pump gasket? [Re: RoadRaceDart] #849003
11/09/10 02:49 AM
11/09/10 02:49 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
.... While you're in there check the oil pump to main cap for passage alignment. you might be surprised at how bad it is.
Yep,
Look closely and you can see the scribe of how far off it was.
