where is the obdI plug? 90 ram van.
#848542
11/07/10 11:45 PM
11/07/10 11:45 PM
Posts: 192 Minnesota
Shaggy
Minnesota
I can't seem to locate it.
1969 Dart
Re: where is the obdI plug? 90 ram van.
[Re: Shaggy]
#848543
11/08/10 01:20 AM
11/08/10 01:20 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
probably under teh dash, pointing down at the carpet somewhere around the steering column...that's where it is on my 98, although it's OBDII, I don't see why they plug locations would change...
**Photobucket sucks**
[Re: gtx6970]
#848545
11/08/10 10:21 AM
11/08/10 10:21 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I agree its under the hood.You will need the chrysler adapter also to hook into it.Rocky
Chrysler Firepower
[Re: Shaggy]
#848547
11/09/10 09:34 AM
11/09/10 09:34 AM
therocks
Niles , Ohio
There were a bunch of different procedures for resetting the maint light.Some had a switch some a battery had to be replaced.You need to find out thru All Data or Mitchells etc how to reset it.Rocky
Chrysler Firepower
[Re: gtx6970]
#848551
11/09/10 08:21 PM
11/09/10 08:21 PM
Shaggy
Minnesota
which light is on?
the ck engine/service engine soon light or the maint required light?
I could just pull the bulb, but would rather not.
Noticed it has a reman computer today.
[Re: Shaggy]
#848552
11/09/10 08:32 PM
11/09/10 08:32 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I have an actron scanner. What needed to be done with the snap on scanner to reset it? I can reset/clear the codes but not the maintanence light....
I had to do a friend's Ram truck too, and can't remember the exact process. It was not in the data and codes menu, it was in a separate area.
[Re: moretoys]
#848554
11/10/10 10:38 AM
11/10/10 10:38 AM
therocks
Niles , Ohio
90 I believe was a battery replace.They used probally 4 or 5 different setups in those years.I do remember some had a switch ubder the dash that needed flipped and some had a button that needed pushed in.Its in All Data how to reset.Id do a Google search and see what it says.Rocky
Chrysler Firepower
