Assembling my stock rebuild 360. buttoned up the bottom end, cam is in place, put the heads on, have the timing cover and water pump in place.
Decided to add oil and prime the oil pump. here is the problem: oil pump primed up nice and everything is oiling except no oil is getting to rocker shaft on the passenger side. Tons of oil flowing on the drivers side to the rockers. removed the rocker shaft and rockers on the passenger side.
It appears there is a single oil passage on the rocker shaft boss nearest the back of the block (second hold down screw) and even with the rocker shaft off....there is no oil coming up through that passage....any thoughts? Do i need to pull that head?
