Re: instigator cuda
[Re: PHJ426]
#848023
12/06/10 03:08 AM
12/06/10 03:08 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
The stimulator is just a testing tool and is not installed into the vehicle....the relay board is mounted seperatly from the main brain board and connected via a 48" DB37 cable....all connections will then be terminated to screw terminals on the relay board...easy to work with and troubleshoot. Here is a pic of the main board I just finished and all testing has passed with it....it sure took a while....probably about 16 hrs building everything and doing all testing/ computer troubleshooting. ![](http://i249.photobucket.com/albums/gg215/turbocuda/IMG_20101206_0021041.jpg) This has it's own aluminum case it slides into to make it nice and neat.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
Re: instigator cuda
[Re: CW25]
#848027
12/07/10 10:57 PM
12/07/10 10:57 PM
instigator
north cakalaky
Went ahead and installed it though going to use my 6AL to fire off the plugs....I have an MSD distributor...wired up the squirt to accept the VR circuit so I am just going to use the reluctor wheel and pickup in the distributor for my RPM sensor..just like I had my DFI.
Re: instigator cuda
[Re: PHJ426]
#848028
12/07/10 11:20 PM
12/07/10 11:20 PM
instigator
north cakalaky
Here is some great reading on the Megasquirt family of control units.....there are lots of options to choose from and really need to read and understand what you need to decide on the appropriate unit....I chose the MS2 which has the ability to fire 8 low impedence injectors in batch fire and full timing contol via map/RPM inputs....also yes the MS2 has e-85 sensor ability and control.....quite a few other controls available with the MS2 they just need to be wired up.
Re: instigator cuda
[Re: instigator]
#848029
12/07/10 11:54 PM
12/07/10 11:54 PM
Posts: 350 Grande Prairie, Alberta, Can.
CW25
Nice, that is what I was running until I decided to go EDIS-8. Doing that mostly for the looks of being able to remove the distributer. Did realize afterwards that I lost my 2 step. DOH!!!Oh well it spends most of its time on the street.
Re: instigator cuda
[Re: CW25]
#848035
12/30/10 08:33 PM
12/30/10 08:33 PM
Posts: 1,049 ohio
all spooled up
ohio
Re: instigator cuda
[Re: CW25]
#848036
03/19/11 05:14 PM
03/19/11 05:14 PM
Posts: 1,049 ohio
all spooled up
ohio
Re: instigator cuda
[Re: CW25]
#848038
03/23/11 12:27 AM
03/23/11 12:27 AM
instigator
north cakalaky
Bout got everything wired up.....should be done tomorrow night!
I'm going to look into a 2-step somehow.
Re: instigator cuda
[Re: CW25]
#848040
03/25/11 11:26 PM
03/25/11 11:26 PM
instigator
north cakalaky
She had fire tonight!....All my sensors were working correctly..though the battery was real low, so could not keep cranking...never got it to idle before the batt was to weak...just going to let it charge tonight....Shouldn't be to much trouble tomorrow to get it to stay lit.
The RPM signal was what I was most worried about though it worked right from the start... That first hit was music to my ears..I knew it would be smooth sailing from there...I'll let yall know how it goes tomorrow.
