Page 2 of 4 1 2 3 4
Re: instigator cuda [Re: instigator] #848001
11/15/10 05:46 PM
11/15/10 05:46 PM
nc
cold85 Offline
cold85  Offline
nc
Here's a fire-up vid...sorry for the angle...I need to turn my phone 90 degrees I guess to vid...enjoy.
http://www.youtube.com/user/turbocuda?feature=mhum#p/a/u/0/1TNycvV4YfU
Hopefully coming to a track soon
Re: instigator cuda [Re: cold85] #848002
11/15/10 10:10 PM
11/15/10 10:10 PM
NICE, i'm a turbo junkie myself!!!!!\
very cool indeed dude!
Re: instigator cuda [Re: instigator] #848003
11/15/10 11:04 PM
11/15/10 11:04 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Here's a few more pics I just took..things are turning out better than I imagined!
nice and clean man! good job!
Mopar Performance
Re: instigator cuda [Re: instigator] #848004
11/16/10 01:47 AM
11/16/10 01:47 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Motor is still 408ci with same shortblock..Mopar Resto-block, callies cranks, manley pro-series I beam rods and Ross pistons....did change main bolts to studs..had Hensley polish crank, rebalance due to new heavier 4340 wrist pins...a complete bottom end freshen....
Went from ported edelbrocks 2.02 1.60 to Indy 360-2 cnc 230cc heads w/ 2.10 1.65's and Indy intake all done by Shady Dell Machine. Cam went from 245-245 .565 lift Flat tappet to 259 255 .630 lift flat tappet..with smith machine composite faced lifters...turbos really stepped up from 61mm P-trims to 75mm gt42 sized turbines ( turbos are probably good for another 500 hp for the pair than compared to the old turbos)...also running a belt drive pump now...also a new bell water to air core in my intercooler (about 50% bigger)...
I am expecting quite a jump in power compared to the old mule.....
I've been working my tail off on a landfill gas job this week so have been really busy and real tired also....have kind of relaxed the last couple nights.
An extra 500 horsepower,so this could potentially make almost 1400 HP?What HP do you expect from it?Did you race it previously and get any ET's?Sounds Great in the video too!
RT
Re: instigator cuda [Re: RTSrunner] #848005
11/16/10 01:55 AM
11/16/10 01:55 AM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
No more cell phone video.I turned the monitor on its side and forgot to put it back.Id had a "few" beers" and the wife was not happy the next morning. Your build inspires me.
Re: instigator cuda [Re: ksj] #848006
11/16/10 03:42 AM
11/16/10 03:42 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
excellent
home of the
Sox and Martin Hemi Duster
Re: instigator cuda [Re: HEMIFRED] #848007
11/18/10 05:25 PM
11/18/10 05:25 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Very nice clean, low profile
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: instigator cuda [Re: Kam*Kuda] #848008
11/19/10 12:15 AM
11/19/10 12:15 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Just got back in from working on it all afternoon....finished drilling/tapping axles and installing 5/8 studs.....got them installed....got wheels back on and driveshaft installed and lowered her back down off the stands....my bud finished hooking up the wastegate control tubing and also got the front set back down..aired up the front and damn if it ain't great to see it on all fours again.
Fired her up, though it was a little tempermental....plugs are probably shot..I ain't to worried bout that cause 10 gallons of E-85 is going in it tomorrow and a fresh set of plugs...shouldn't have to worry bout fouling plugs again after that.....
Also put trans in gear and all seemed well with the trans so far....
one more thing...scheduled to go to the dyno with it on Saturday! :biggrin
I am expecting 4-digit #'s...and probably rather easily !
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: instigator cuda [Re: instigator] #848009
11/19/10 02:41 AM
11/19/10 02:41 AM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
You need to go on DragWeek in the SB/PA class.Cant wait to see the numbers.
Re: instigator cuda [Re: ksj] #848010
11/20/10 12:47 AM
11/20/10 12:47 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Put 12 gallons of E-85 in it tonight..put a new set of plugs gapped at .020 and checked the valves.all were good.....added a bit of fuel to the map and got it fired...had to keep leaning it down to get it to run...though I was so happy when I saw it idling at 15 + to 1 afr....I can see no more fouled plugs in my future!
Will be out early in the morning to get some last minute things done and get to the Dyno tomorrow...2pm....
65 Barracuda
Re: instigator cuda [Re: all spooled up] #848011
11/20/10 01:10 AM
11/20/10 01:10 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
What brand elbow are you running? Whats that throttle body off of? Looks cool!
Re: instigator cuda [Re: Quicksilver440] #848012
11/20/10 01:18 AM
11/20/10 01:18 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
I cut the aluminum elbow off an old truck turbo my buddy had...the plates I machined myself...and just welded it together..3 inch id at the throttlebody and 3.5" id at the manifold...the throttlebody is an edelbrock 75mm
65 Barracuda
Re: instigator cuda [Re: instigator] #848013
11/20/10 10:50 AM
11/20/10 10:50 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
good luck my friend i hope ya have a good day at the dyno
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: instigator cuda [Re: Ian] #848014
11/20/10 12:04 PM
11/20/10 12:04 PM
ohio
all spooled up Offline OP
ohio
good luck have fun brian
Re: instigator cuda [Re: all spooled up] #848015
11/21/10 05:46 PM
11/21/10 05:46 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
After a morningh of frustrations...and finally making it to the dyno late....finally got to do some cruise tuning on the loaded muystang dyno...got to smoothe out some rough areas in the tables.....made a couple power pulls on 10 psi to just 4800, just to check out the afr....was making adjustments and that was when the last problem arised in the day..my laptop would not communicate with the dfi anymore. and also wiped out all the previos tuning.....I hate electronic problems .
Had to push it on to the trailer.....
Did make 459hp 497 torque at 4800 rpms.....
65 Barracuda
Re: instigator cuda [Re: instigator] #848016
11/23/10 11:58 PM
11/23/10 11:58 PM
ohio
ohio
you get it
Re: instigator cuda [Re: all spooled up] #848017
11/24/10 08:50 PM
11/24/10 08:50 PM
Man, I want one of those! looks really neat, Good Luck with it.
Re: instigator cuda #848018
11/29/10 10:22 PM
11/29/10 10:22 PM
ohio
ohio
did you get it back on the rollers
Re: instigator cuda [Re: all spooled up] #848019
11/30/10 04:27 PM
11/30/10 04:27 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Just got a megasquirt 2 ordered yesterday...should be here this week...I plan on getting it installed this weekend....less than500$ for the brain,relay board,cables,and test board.
65 Barracuda
Re: instigator cuda [Re: instigator] #848020
12/01/10 12:38 AM
12/01/10 12:38 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
If ya need any help don't hesitate to ask. I may be able to help. I never bothered with the relay board as found it easier to wire direct. Just used my own relays.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Page 2 of 4 1 2 3 4
