Re: instigator cuda
[Re: cold85]
#848002
11/15/10 10:10 PM
11/15/10 10:10 PM
NICE, i'm a turbo junkie myself!!!!!\ very cool indeed dude!
Re: instigator cuda
[Re: Kam*Kuda]
#848008
11/19/10 12:15 AM
11/19/10 12:15 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Just got back in from working on it all afternoon....finished drilling/tapping axles and installing 5/8 studs.....got them installed....got wheels back on and driveshaft installed and lowered her back down off the stands....my bud finished hooking up the wastegate control tubing and also got the front set back down..aired up the front and damn if it ain't great to see it on all fours again. Fired her up, though it was a little tempermental....plugs are probably shot..I ain't to worried bout that cause 10 gallons of E-85 is going in it tomorrow and a fresh set of plugs...shouldn't have to worry bout fouling plugs again after that..... Also put trans in gear and all seemed well with the trans so far.... one more thing...scheduled to go to the dyno with it on Saturday! ![](/ubbthreads/images/graemlins/biggrin.gif) :biggrin I am expecting 4-digit #'s...and probably rather easily !
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
Re: instigator cuda
[Re: ksj]
#848010
11/20/10 12:47 AM
11/20/10 12:47 AM
instigator
north cakalaky
Put 12 gallons of E-85 in it tonight..put a new set of plugs gapped at .020 and checked the valves.all were good.....added a bit of fuel to the map and got it fired...had to keep leaning it down to get it to run...though I was so happy when I saw it idling at 15 + to 1 afr....I can see no more fouled plugs in my future!
Will be out early in the morning to get some last minute things done and get to the Dyno tomorrow...2pm....
Re: instigator cuda
[Re: instigator]
#848013
11/20/10 10:50 AM
11/20/10 10:50 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
good luck my friend i hope ya have a good day at the dyno ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: instigator cuda
[Re: all spooled up]
#848015
11/21/10 05:46 PM
11/21/10 05:46 PM
instigator
north cakalaky
After a morningh of frustrations...and finally making it to the dyno late....finally got to do some cruise tuning on the loaded muystang dyno...got to smoothe out some rough areas in the tables.....made a couple power pulls on 10 psi to just 4800, just to check out the afr....was making adjustments and that was when the last problem arised in the day..my laptop would not communicate with the dfi anymore. and also wiped out all the previos tuning.....I hate electronic problems ![](/ubbthreads/images/graemlins/flame.gif) . Had to push it on to the trailer..... Did make 459hp 497 torque at 4800 rpms.....
Re: instigator cuda
#848017
11/24/10 08:50 PM
11/24/10 08:50 PM
Man, I want one of those! looks really neat, Good Luck with it. ![](/ubbthreads/images/graemlins/thumbs.gif)
