Page 1 of 4 1 2 3 4
instigator cuda #847981
11/07/10 01:48 PM
11/07/10 01:48 PM
ohio
all spooled up Offline OP
ohio
let us know how she runs and some more pics
Re: instigator cuda [Re: all spooled up] #847982
11/07/10 06:36 PM
11/07/10 06:36 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Been widdling away at it today...things are coming around....got downpipe wrapped and installed....just made up new wires....going to keep working on it tonight but won't be no vroom vroom tonight.....maybe tomorrow evening.
I'll post up some new pics later on.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: instigator cuda [Re: instigator] #847983
11/07/10 09:34 PM
11/07/10 09:34 PM
ohio
ohio
Re: instigator cuda [Re: all spooled up] #847984
11/07/10 09:58 PM
11/07/10 09:58 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Here's a few more pics I just took..things are turning out better than I imagined!
65 Barracuda
Re: instigator cuda [Re: instigator] #847985
11/08/10 12:43 AM
11/08/10 12:43 AM
ohio
ohio
you got alot done you going dyno it
Re: instigator cuda [Re: all spooled up] #847986
11/08/10 01:01 AM
11/08/10 01:01 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Oh yea....and I also got the stock ralley hood (fiberglass re-pop) to clear...just had to noth a little here and there on some of the "bracing"....
I was really glad of this.
may make it to the dyno next week.... will have to see.
65 Barracuda
Re: instigator cuda [Re: instigator] #847987
11/08/10 11:11 AM
11/08/10 11:11 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Awesome!
Re: instigator cuda [Re: instigator] #847988
11/08/10 11:24 AM
11/08/10 11:24 AM
State College, Pennsylvania
fatman Offline
fatman  Offline
I'm having trouble thinking up a more desirable combo.
Re: instigator cuda [Re: fatman] #847989
11/08/10 04:49 PM
11/08/10 04:49 PM
California
hemibill Offline
hemibill  Offline
California
How are you going to connect the turbos to an air cleaner? It appears there is zero room on one side and very little room on the other, for piping. And I don't see any big holes in the side area of the radiator core support.
I like what you've done too! (Just wondering out loud).
BILL
Stop making excuses... start making SOLUTIONS!
Re: instigator cuda [Re: hemibill] #847990
11/08/10 08:04 PM
11/08/10 08:04 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
BILL
Bill, there is a nice sized hole on the driver side already where the turbo is close, but no hole on the passenger side where there is quite a bit more room( can get air from all around).....though I only plan on running a screen over the compressor inlets to keep rocks and debris out....I'll kep the oil changed enough to not worry about filters very much
65 Barracuda
Re: instigator cuda [Re: instigator] #847991
11/09/10 01:53 AM
11/09/10 01:53 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
What's new with the motor?I can tell by your sig photo the turbos are moved forward,bigger motor,bigger turbos?What kind of power do you expect?That 895rwp number seemed pretty good!
RT
Re: instigator cuda [Re: RTSrunner] #847992
11/09/10 07:43 PM
11/09/10 07:43 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
RT
Motor is still 408ci with same shortblock..Mopar Resto-block, callies cranks, manley pro-series I beam rods and Ross pistons....did change main bolts to studs..had Hensley polish crank, rebalance due to new heavier 4340 wrist pins...a complete bottom end freshen....
Went from ported edelbrocks 2.02 1.60 to Indy 360-2 cnc 230cc heads w/ 2.10 1.65's and Indy intake all done by Shady Dell Machine. Cam went from 245-245 .565 lift Flat tappet to 259 255 .630 lift flat tappet..with smith machine composite faced lifters...turbos really stepped up from 61mm P-trims to 75mm gt42 sized turbines ( turbos are probably good for another 500 hp for the pair than compared to the old turbos)...also running a belt drive pump now...also a new bell water to air core in my intercooler (about 50% bigger)...
I am expecting quite a jump in power compared to the old mule.....
I've been working my tail off on a landfill gas job this week so have been really busy and real tired also....have kind of relaxed the last couple nights.
65 Barracuda
Re: instigator cuda [Re: instigator] #847993
11/09/10 10:49 PM
11/09/10 10:49 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Sounds like you spent the money in all the right places. That thing should be a rocket.
Re: instigator cuda [Re: TRENDZ] #847994
11/10/10 10:53 AM
11/10/10 10:53 AM
Houston, Texas
Houston, Texas
YIKES! I can't wait to see how she runs!
Re: instigator cuda [Re: TheOtherDodge] #847995
11/14/10 11:54 AM
11/14/10 11:54 AM
ohio
ohio
is she running
Re: instigator cuda [Re: all spooled up] #847996
11/14/10 10:03 PM
11/14/10 10:03 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
She fired up about an hour ago......
Spent most of the day jacking with the beld-drive pump...finally figured it out and got it to move fuel....also had to get my old laptop to connect to the DFI....once worked all this and playing with distributor she fired up...took some tweaking by addig fuel to keep her running....once this was done it ran real clean, no leaks, no ticks, no problems what so ever....got it up to 195 and shut her down....
Boy does it sound good!...
I was by myself so no time to video...phone was dead also..sorry.
EDIT--just took a couple minutes and made a vid...check back soon, I will de downloading soon.
65 Barracuda
Re: instigator cuda [Re: instigator] #847997
11/14/10 11:09 PM
11/14/10 11:09 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Here's a fire-up vid...sorry for the angle...I need to turn my phone 90 degrees I guess to vid...enjoy.
http://www.youtube.com/user/turbocuda?feature=mhum#p/a/u/0/1TNycvV4YfU
65 Barracuda
Re: instigator cuda [Re: instigator] #847998
11/14/10 11:26 PM
11/14/10 11:26 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
WOW!!!
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: instigator cuda [Re: Cudahlr] #847999
11/15/10 12:36 AM
11/15/10 12:36 AM
ohio
ohio
Re: instigator cuda [Re: all spooled up] #848000
11/15/10 11:18 AM
11/15/10 11:18 AM
Houston, Texas
Houston, Texas
So sweet!!!!
Page 1 of 4 1 2 3 4
