What size wire......? #84794
07/06/08 12:56 PM
07/06/08 12:56 PM
In a van, down by the river
jmf340 Offline OP
jmf340  Offline OP
What size wire was used to go from the starter relay over to the alternator on a 73 Dart? Should the same size be used, when being replaced, or should I upgrade? Thanks in advance.
Got Mopar???
Re: What size wire......? [Re: jmf340] #84795
07/06/08 01:09 PM
07/06/08 01:09 PM
Original was no12, and that should be plenty.
More important, use a piece of high quality, flexible wire, because the engine MOVES. Route the wire with so it's got sort of a loop to allow for some flex.
I've seen more than one original break off right "in" the wire end terminal
Re: What size wire......? [Re: jmf340] #84796
07/06/08 05:39 PM
07/06/08 05:39 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Be sure the wire is a stranded type, many little wires. Also solder the terminals and heat shrink each end.
Just my $0.02..
