98 ram 1500 brake issue #847619
11/06/10 09:58 PM
11/06/10 09:58 PM
central illinois
65dodgebob Offline OP
central illinois
could use some tech advice. abs and brake dash lites are on, no obvious brake problems,fuses good, etc,where to start? happened after pulling trailer thru some hills.
Re: 98 ram 1500 brake issue [Re: 65dodgebob] #847620
11/06/10 11:37 PM
11/06/10 11:37 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
you might have run over something that hit the connector and dislodge it.. might check your connection...
Re: 98 ram 1500 brake issue [Re: BigTerry] #847621
11/07/10 02:15 AM
11/07/10 02:15 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Check the speed sensor in the rear axle. When the sensor fails it cannot tell how fast the wheels are turning and the computer activates the ABS and brake warning lights..
Re: 98 ram 1500 brake issue [Re: 65dodgebob] #847622
11/07/10 02:37 AM
11/07/10 02:37 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I have the 1998 service book in my computer files. I can email you the brake section if you need it. Let me know.
Fred
Re: 98 ram 1500 brake issue [Re: 52savoy] #847623
11/07/10 10:05 PM
11/07/10 10:05 PM
central illinois
central illinois
thanks for the help guys, i will try replacing speed sensor.
