holley avenger to a518
#846947
11/05/10 10:13 PM
11/05/10 10:13 PM
Posts: 118 Sarasota, Fl
siggie30
Sarasota, Fl
Reading up on the holley site about my carburetor states not to use my model for a automatic overdrive transmission. I thought I would defer to the masses and ask why or why not. Seeing as I am using the vacuum system why would the carb have any issue with the linkage?
I don't even have 1/2 lift, but the other 1/2 is nitroused.
Re: holley avenger to a518
[Re: stumpy]
#846949
11/06/10 09:20 AM
11/06/10 09:20 AM
siggie30
Sarasota, Fl
Thanks for the reply. Are they compatible, or is Holley covering their butt?
[Re: siggie30]
#846950
11/06/10 09:37 AM
11/06/10 09:37 AM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I am using Road Demon Jr with the A518. No problems, you will need a mechanical kickdown of some sort.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: Rick_Ehrenberg]
#846952
11/07/10 08:34 PM
11/07/10 08:34 PM
siggie30
Sarasota, Fl
These are the brackets I have. The chrysler arm adapter is loosely installed.
