340 overheating problems
#846605
11/05/10 04:24 PM
11/05/10 04:24 PM
Posts: 176 Ohio
440727
Ohio
My brother has a 1973 dodge Challenger with a fresh 340 putting out around 400hp. He has a 180* thermostat, aluminum radiator, and clutch fan.
Well the car wants to overheat really fast at an idling or or under 30mph.
We know the clutch fan is working.
Now the initial timing for some reason bounces from 8-10* with an total advance of 34* at 2500 rpms. Car is idling at 1100rpms since its where the engine idles best. The 340 has a Voodoo 512 lift cam.
We're using an Accel vacuum advance distributor although the vacuum ports are plugged. Reason being the car will not run with the vacuum advance hooked up. The rpms are all over the place ranging from 800-2500rpms with the vacuum advance hooked up. We do have a vacuum canister also.
The car idles ok as is and runs like a wild indian on the road.
I'm thinking the initial timing isn't enough ?
Thanks guys !
Re: 340 overheating problems
[Re: 440727]
#846607
11/05/10 05:23 PM
11/05/10 05:23 PM
RapidRobert
What adv springs? as the bouncing is from either too light of springs or the dist tang fitting too loose in the top of the inter gear/shaft/. Twist the rotor by hand back & forth being carefull not to get into the spring tension & see how much play there is. It's also classic sloppy tchain but assuming you replaced them w this being a rebuild. Sumpin ain't right as it shouldn't need to idle that high & yes I'd stabilize the initial & get the idle sp lowered. I'm doing alot of speculating here but holler back & we'll continue on.
[Re: 440727]
#846608
11/05/10 05:47 PM
11/05/10 05:47 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
What kind of temperature are you seeing?
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: thedriver]
#846617
11/05/10 06:33 PM
11/05/10 06:33 PM
RapidRobert
If the timing is not retarded at the offending speed I'll say not enough air flow thru the rad
[Re: 440727]
#846619
11/05/10 07:08 PM
11/05/10 07:08 PM
RapidRobert
the initial timing bounces from 8-10* with an total advance of 34* at 2500 rpms. Car is idling at 1100rpms
[Re: RapidRobert]
#846620
11/05/10 07:19 PM
11/05/10 07:19 PM
Posts: 176 Ohio
440727
Ohio
Sorry I didn't explain it well.
When you have the timing light on the harmonic balancer you can see when idling at 1100rpms the timing bounces from 8*-10* and sometimes up to 8*-12*
Also the radiator is a Jegs 2 row 1" core aluminum radiator.
Thanks guys
[Re: 440727]
#846621
11/05/10 07:27 PM
11/05/10 07:27 PM
RapidRobert
Actually you exp it well & it was my chart/post not being specific about what I was saying (or trying to say ). Bouncing marks are from sloppy tchain or dist tang or dist weights bouncing from light springs or bad connection in the light (had one like that). I would get the idle sp lowered/timing in the ballpark & see that the rad has good airflow (no excessive obstructions either sheetmetal ductwork or condensor/aux cooler). EDIT assuming the shroud/fan location in the shroud are right & you said the fan is tight
[Re: 440727]
#846624
11/05/10 07:52 PM
11/05/10 07:52 PM
Challenger 1
Cincinnati, Ohio
Thanks guys
The reason you have to idle it at 1100 rpm is because you don't have enough intial timing with that performance cam. Give it more timing at idle and you will then be able to get it to idle at 800, no problem. Then you can adjust your idle mixture screws. Try it, your'll like it.
Of course your'll have to limit your total timing to like 35 or so like what was suggested.
