I'd pull it immed & reset it & hope you get it clos(er) to where it (originally) was b 4 it beds in to the pattern that you set it to when you added the sure grip. they say it's hard to totally quiet a noisy set but might make some improvment & I'd get on it asap & hope for the best. Do ya feel lucky, well do ya. EDIT look up the rear axle troubleshooting charts for a whine on accel & see if the backlash needs to be increased or decreased. Might get you in the right direction. Really needed the orig backlash figure at the tightest point b 4 dissassembly
