Re: Vibration damper/key questions
[Re: buildanother]
#846492
11/05/10 02:47 PM
11/05/10 02:47 PM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
And the crank timing sproket floats unless the balancer cranks tight against it. So if the balancer was moving around, so was the sproket. Hope the crank is still good for your sake.
Thanks guys, Yes I agree that the timing sprocket would 'float' along with the damper in this case that I described, but please clarify--the damper hub SHOULD press tightly (from the crank bolt/washer) against the timing sprocket correct?
I did have to use a puller to slide the damper off, so I am thinking (hoping) the root-cause is the main bolt contacting the crank snout before seating against the damper. I will check the length of the bolt itself to make sure its not too long.
[Re: Pacnorthcuda]
#846493
11/05/10 02:50 PM
11/05/10 02:50 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
No , the dampner should not move at all once it pressed on, I don't think there is much more than .020-.030 of hub past the end of the crank. The bolt holds it tight against the crank sprocket, not from rotating.
