Re: NHRA: SFI Padding now required under 10.0 [Re: kissmyaspen] #846208
11/05/10 12:46 PM
11/05/10 12:46 PM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
Can anyone show me where non-SFI padding has resulted in an injury that the SFI padding would have prevented? Just wondering?
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
Re: NHRA: SFI Padding now required under 10.0 [Re: kissmyaspen] #846209
11/05/10 12:48 PM
11/05/10 12:48 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I thought the major difference between SFI padding and the cheap stuff is fireproofing..
Correct me if I'm wrong..
Re: NHRA: SFI Padding now required under 10.0 [Re: LoneMopar] #846210
11/05/10 12:55 PM
11/05/10 12:55 PM
organ
maximum entropy Offline
organ
the solution is simple, really. if you don't mind all the regulations, and can afford it, just race as fast as you can! if you can't afford it (that would be me), don't! i'll keep pouring money into that black hole in my shop, but it will be a street car (a very fast street car). i'll get a honda civic wagon for bracket racing. i may even tow it with the scamp. hmm.
Re: NHRA: SFI Padding now required under 10.0 [Re: LoneMopar] #846211
11/05/10 01:30 PM
11/05/10 01:30 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
http://www.jegs.com/i/Kirkey/570/99011/10002/-1
$17.99 a stick, and one stick should cover what you need. If you have a NHRA number/membership, it's even less. The cheap stuff is $4. If a extra $14 is going to break the bank, it's time to find a new hobby.
Re: NHRA: SFI Padding now required under 10.0 [Re: JERICOGTX] #846212
11/05/10 01:34 PM
11/05/10 01:34 PM
tboomer Online work
tboomer  Online Work
Jeff....I wonder who makes that stuff...Sure looks like Armaflex pipe insulation that I used to use when I worked with commercial refrigeration stuff... I am sending you a pm...
Re: NHRA: SFI Padding now required under 10.0 [Re: tboomer] #846213
11/05/10 05:57 PM
11/05/10 05:57 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
So that begs the question.... how do they tell SFI padding from non-SFI? A sticker? An imprint?
Next, I bet they'll require you to get SFI approved flame resistant zip-ties to install it.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: NHRA: SFI Padding now required under 10.0 [Re: BBR] #846214
11/05/10 06:02 PM
11/05/10 06:02 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
It's applied with 2 face tape. Stays put where you put it. The cheap stuff is only thick on one side. It can roll on the tube exposing the thin side. Maybe this is another reason for the SFI stuff?
69 GTX 68 Road Runner
Re: NHRA: SFI Padding now required under 10.0 [Re: BBR] #846215
11/05/10 06:13 PM
11/05/10 06:13 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Don't Laugh!!!! That seems to be the direction they're going.
Let's see now.......Regular Zap-straps only $5.99 per 100. SFI "NHRA Approved" Zap-straps $5.99 each.
Re: NHRA: SFI Padding now required under 10.0 [Re: BBR] #846216
11/05/10 06:15 PM
11/05/10 06:15 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Click on the Jegs link above and look at the JAZ padding listed below the Kirkey padding. It has an SFI label all the way down the pad.
Re: NHRA: SFI Padding now required under 10.0 [Re: Dart1031] #846217
11/05/10 06:24 PM
11/05/10 06:24 PM
organ
organ
there's gonna be two types of sfi labels. you know where i'm going with this...
