Re: NHRA: SFI Padding now required under 10.0
[Re: BBR]
#846214
11/05/10 06:02 PM
11/05/10 06:02 PM
Posts: 10,032 MN
JERICOGTX
MN
It's applied with 2 face tape. Stays put where you put it. The cheap stuff is only thick on one side. It can roll on the tube exposing the thin side. Maybe this is another reason for the SFI stuff?
69 GTX
68 Road Runner
[Re: BBR]
#846215
11/05/10 06:13 PM
11/05/10 06:13 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
So that begs the question.... how do they tell SFI padding from non-SFI? A sticker? An imprint?
Next, I bet they'll require you to get SFI approved flame resistant zip-ties to install it.
Don't Laugh!!!! That seems to be the direction they're going.
Let's see now.......Regular Zap-straps only $5.99 per 100. SFI "NHRA Approved" Zap-straps $5.99 each.
[Re: BBR]
#846216
11/05/10 06:15 PM
11/05/10 06:15 PM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
Click on the Jegs link above and look at the JAZ padding listed below the Kirkey padding. It has an SFI label all the way down the pad.
[Re: Dart1031]
#846217
11/05/10 06:24 PM
11/05/10 06:24 PM
Posts: 5,080 organ
maximum entropy
organ
there's gonna be two types of sfi labels. you know where i'm going with this...
