yep car was running great 1st pass of the trailer it ran a 9.901 at 131 lifting about the 1000' mark because I seen a flash I through was the score board but it was my shift light
so made a couple more passes before starting to try and slow it down to run the 10.0 class and got a beat of 9.768 at 138
a few more passes and had the car slowed down running a 10.04 and a 10.05 during quilifying also went ahead and had JT cert the chassis since he was there so now it good to 8.50
any way go up for 1st round every thing is good set the brake light comes down let go and all the sunned car is banging and missing like it's on the 2 step make a quick check all gauges are fine no smoke just no power other guy breaks out so I get the win but car is done havent pulled it apart yet but believe I lost the left head gasket water in left cylinders but not in vc or oil no nocking noise goo oil presser so we will see.
Hope it's not to bad as i am having to take a new job at a 10.00 per hour pay cut thanks to our economy.
