408 stroker pistons
#845572
11/04/10 12:41 AM
11/04/10 12:41 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
My sons assembling a 408 stroker.He has some KB pistons with a raised portion on them.CR is 9.5 The machine shop installed them on the rods and told him they are correct.They don't look right to me.The raised portion is at the bottom of the pic which would be closest to the lifter valley
NS1AAR
Re: 408 stroker pistons
[Re: ns1aar]
#845578
11/04/10 09:29 AM
11/04/10 09:29 AM
Posts: 892 Illinois
StrkrDart69
Illinois
The raised area of the piston should be on the top,closest to the lifter valley. Your pic shows them installed correctly.
[Re: StrkrDart69]
#845579
11/04/10 11:24 AM
11/04/10 11:24 AM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
[Re: justinp61]
#845580
11/04/10 11:33 AM
11/04/10 11:33 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
They are installed correctly but if they are a closed chamber head they need to come back out and get the raised part milled off or get POS open chamber heads.
[Re: HotRodDave]
#845581
11/04/10 05:39 PM
11/04/10 05:39 PM
RapidRobert
that's what I was wondering & dont modern bearings not have the groove to feed oil to the rod squirt hole groove as engineers decided that enough oil was being splashed up there as is ?? but I do remem that the large rod chamfer goes toward the outside crank face not inward to the adjacent rod?? EDIT then I read the subsequent post that they clear w the gasket so how much clearance do they have & what actual CR, what heads/what octane?
