66 Coronet---What Tires Will Fit? #845485
11/03/10 11:30 PM
11/03/10 11:30 PM
cousinbob Offline OP
Can anyone tell me what is the biggest rear tire you can fit in a 66 Coronet where the stock tubs have been widened just to the frame rail? I don't want to modify it any more than that. I'm hoping to run at least a 10-11" slick, 29-30" tall on a 10" rim.
Re: 66 Coronet---What Tires Will Fit? [Re: cousinbob] #845486
11/04/10 09:59 AM
11/04/10 09:59 AM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
I have 29.5 x 13.5 under mine, springs moved in to the frame
Re: 66 Coronet---What Tires Will Fit? [Re: Thor500] #845487
11/04/10 03:00 PM
11/04/10 03:00 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Basically it is the same with a 67 Coronet - I got 325x15x60s M/T drag radials under mine after moving in the inner wheel well and springs to the frame using the relocation kit.
Re: 66 Coronet---What Tires Will Fit? [Re: cousinbob] #845488
11/04/10 04:52 PM
11/04/10 04:52 PM
organ
maximum entropy Offline
organ
you'll be able to run the largest possible. any larger than that, and there'll be big trouble.
Re: 66 Coronet---What Tires Will Fit? [Re: maximum entropy] #845489
11/04/10 06:36 PM
11/04/10 06:36 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
wheel wells move in and springs move in..30x11 could go 11.5 wide
Re: 66 Coronet---What Tires Will Fit? [Re: maximum entropy] #845490
11/04/10 06:38 PM
11/04/10 06:38 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Re: 66 Coronet---What Tires Will Fit? [Re: cousinbob] #845491
11/05/10 10:48 PM
11/05/10 10:48 PM
Gentlemen, thanks for the replies. My car is a two door post, and I just picked it up today. Jim and Dave, hope my car turns out as nice as yours.
Re: 66 Coronet---What Tires Will Fit? [Re: cousinbob] #845492
11/05/10 10:50 PM
11/05/10 10:50 PM
Jamie, your's look pretty sharp, too. The 66 and 67 Coronets are probably my favorite Mopar!
