Odd problem-- 2 step / transbrake #845197
11/03/10 06:18 PM
11/03/10 06:18 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Im having a problem with the car dying on the line.
This has only happened 2 times this year.
When i bring up the motor on the 2 step, it hits it a few times and the motor dies instantly. This is before i release the button .
After that i put in park and the car starts right up.
So then i just footbrake it and the car runs fine.
Has anyone had this happen?
its a msd soft touch + 2 step + chrome box
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845198
11/04/10 08:27 AM
11/04/10 08:27 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
Low voltage to ignition possibly? I had that happen but was running an MSD 6 AL, Isolated my 2 batteries, 1 to electronics and 1 for everything else and it never was a problem again.
Re: Odd problem-- 2 step / transbrake [Re: Cuda_Mike] #845199
11/05/10 02:47 AM
11/05/10 02:47 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Msd suggested running a lone 12v hot to the 2 soft touch .
i might try it and test the brake in my garage next week about 10 times .
The neighbors will love it
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845200
11/05/10 09:08 PM
11/05/10 09:08 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
So it dies after you go to WOT? What rpm do you have the 2 step at? I know my car doesnt like being on the 2 step at WOT under 3000rpm.After the pump shot is used up there isn't enough signal to pull the fuel out of the bowls. Could this be what is happening?
Re: Odd problem-- 2 step / transbrake [Re: 10sec440] #845201
11/05/10 09:15 PM
11/05/10 09:15 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I've ran a +.030 340, a +.030 360 and currently run a 4.040-3.790 388, and I've left with all of them from 2100 to 3000. FYI.
Re: Odd problem-- 2 step / transbrake [Re: 10sec440] #845202
11/05/10 09:46 PM
11/05/10 09:46 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
its at 3000 , yes at wot. right at the 1st bulb.
is it possible its just running out of fuel ???
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845203
11/05/10 09:49 PM
11/05/10 09:49 PM
Hemiroid Offline
Hemiroid  Offline
Probably the Chrome box...
Re: Odd problem-- 2 step / transbrake [Re: Leigh] #845204
11/06/10 12:43 AM
11/06/10 12:43 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
It depends on the setup. For example if it's overcarbed, it will be more likely this could happen. Your results may vary!
Re: Odd problem-- 2 step / transbrake [Re: 10sec440] #845205
11/06/10 11:15 AM
11/06/10 11:15 AM
Santa Rosa,CA USA
67dodgeracer Offline
Santa Rosa,CA USA
I had your exact same problem when I tried a transbrake.I run a stock 9375 Dominator.Went up and down in squirters,different pump cams,etc. all to no avail.Threw my dynomax bullets on while trying in the garage.That helped some,but what really fixed it was a 'shear' plate,a tapered (7 degree,I think)spacer that goes under the carb.It's designed to boost the signal to the carb and help the motor pull fuel.Not saying this is your problem but it could be worth a try.Good luck.
Re: Odd problem-- 2 step / transbrake [Re: 67dodgeracer] #845206
11/06/10 04:35 PM
11/06/10 04:35 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
so 67 , did your engine die instantly like i described?
what squirters / cams did you end up with ?
the 1st time i was on the 2 step for a long time,4-5 seconds .
the 2nd time i was on it maybe 2 seconds.
the other 35 passes it ran fine.
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845207
11/06/10 06:02 PM
11/06/10 06:02 PM
Santa Rosa,CA USA
Santa Rosa,CA USA
Yeah mine died before it even reached the chip.It was pretty bad.It was ok if I put the throttle down slower,but I couldn't overcome years of matting the throttle the way I do and go slower all of a sudden.I ended up running what the carb came with..35 squirters and yellow cams.I could footbrake it with the 2 step button on the brake pedal,and it would be fine(before I tried the shear plate).My motor went on the chip alot quicker with the transbrake,so I figured with my setup,which is a 4500 base M1 manifold,that it wasn't pulling fuel from the carb like it should.
Re: Odd problem-- 2 step / transbrake [Re: 10sec440] #845208
11/07/10 08:16 AM
11/07/10 08:16 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
3310 to 8896, and several in between.
Re: Odd problem-- 2 step / transbrake [Re: Leigh] #845209
11/07/10 04:19 PM
11/07/10 04:19 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
can you send me a link for that shear plate?
this is frustrating but i guess i can at least test the car at home
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845210
12/05/10 06:57 PM
12/05/10 06:57 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I was thinking about this today (while staring out the frozen window) - nobody i know runs a shear plate and their cars DONT stall like mine has . So i cant justify buying a $90 carb spacer. i appreciate the idea 67 , but....
without throwing $ at it , i might try different pump cams and squirters
anyone else want to throw some ideas around ?
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845211
01/15/11 03:10 AM
01/15/11 03:10 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
BUMP -------- anyone ?
cabin fever is full on now .......
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845212
01/15/11 01:33 PM
01/15/11 01:33 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
The ecclerarator pumps don't really matter on t brake car, on launch .
Unless you are bogging going into full throttle .
Raise fuel bowls up some might be running low on WOT .
Also try not getting into 2step as long or wait as if tree is coming down .
In a bracket handicap 4sec is a loooonggggggg time to be on brake .
Good luck .DR
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Odd problem-- 2 step / transbrake [Re: 10 o to go] #845213
12/17/11 04:42 AM
12/17/11 04:42 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I forgot about this post !
The problem was I was on the brake too long----running out of fuel .
I changed my technique during 2011 and the problem was eliminated .
Thanks guys
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845214
12/17/11 07:23 AM
12/17/11 07:23 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
You need to spend some money on the heating.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Odd problem-- 2 step / transbrake [Re: deaks] #845215
12/17/11 08:02 AM
12/17/11 08:02 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I cant afford the bloody heating bills Mick !!
Brutal cold is going to kick in here until March
Re: Odd problem-- 2 step / transbrake [Re: 493_DART] #845216
12/17/11 02:20 PM
12/17/11 02:20 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
Come to Arizona and go racing on New Years Day! When I lived in Pennsyltucky, I really envied the people that could race over the holidays...now I am one of them!
