pilot bearing removal #844989
11/03/10 01:12 AM
11/03/10 01:12 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
any suggestion to remove a pilot bearings??? ive tried pullers and filling the opening with grease and slamming a steel dowel but the thing wont budge
Re: pilot bearing removal [Re: kingkt] #844990
11/03/10 01:26 AM
11/03/10 01:26 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I did the same as you, it wouldnt budge.. finally I took a die grinder and cut a couple of grooves in the bearing and then took a punch and hammer and beat / chipped it out...No fun..
Re: pilot bearing removal [Re: sthemi] #844991
11/03/10 01:41 AM
11/03/10 01:41 AM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
yeah no fun i was thnking to tap some threads and screw a bolt and attach to my dent puller but ill need to get a tap that size tomorrow
Re: pilot bearing removal [Re: kingkt] #844992
11/03/10 10:47 AM
11/03/10 10:47 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Step back and slow down , it take some time to work those things out , if you take wet paper towel and a dowel rod that fits properly and a hammer . keep filling the back side with wet paper towels and use the hammer to push the towels in it will eventually come out i guarantee it if done right . i have used this method for years never had one not come out i believe it is impossible for it not to work because of the hydraulic pressure just keep filling the hole with paper towel that is the deal !
1969 Dodge Charger 1969 Dodge Superbee
Re: pilot bearing removal [Re: kingkt] #844993
11/03/10 12:09 PM
11/03/10 12:09 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
If you have a tap that fits, just keep threading it all the way in. When the tap hits bottom, keep going, and it will force the bushing out. Or, after you've cut the threads, replace it with a bolt and use that to force the bushing out.
Re: pilot bearing removal [Re: twodoorpost] #844994
11/03/10 02:46 PM
11/03/10 02:46 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
break that tap and you'll have a real mess
Re: pilot bearing removal [Re: theclutcher] #844995
11/03/10 03:02 PM
11/03/10 03:02 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
It's really no big deal. Take a die grinder and mske a cut lengthwise and it will just about fall out. Done dozens this way over the years with no problem.
MB
Re: pilot bearing removal [Re: HPMike] #844996
11/03/10 03:14 PM
11/03/10 03:14 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Find a piece of rod that is a close fit to the diameter of the pilot bushing. It does not have to be an exact fit but the closer it is the better. Take the grease gun and pump the bushing nearly full. Insert the rod and give it a good whack on the end with a hammer and the grease will force the bushing right out.
Getting old just means you were smarter than some and luckier than others.
Re: pilot bearing removal [Re: dannysbee] #844997
11/04/10 11:22 AM
11/04/10 11:22 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
65 Barracuda
70 Challenger
Re: pilot bearing removal [Re: jrwoodjoe] #844998
11/05/10 06:12 PM
11/05/10 06:12 PM
Middle TN
da50r Offline
da50r  Offline
Middle TN
Grease method
http://www.youtube.com/watch?v=WSGD9UuI5-I&feature=related
Paper method
http://www.youtube.com/watch?v=1xuR7T8G1Ys [/quote
That tap idea is suicide...
I've just used all thread, or a rod, 3/4" extension, something like that, grease and about 3-4 good solid hits. I watched that youtube... I didnt get all that non sense with the bolt, and socket, but it's the same idea...
