Pictures of 2x4 carb linkage wanted #844510
11/02/10 06:58 PM
11/02/10 06:58 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Would like to see different 2x4 linkages hooked up so i can make up my mind which linkage to do.Going on a hemi in a willis.Would like something different.
Re: Pictures of 2x4 carb linkage wanted [Re: gtx69] #844511
11/02/10 07:48 PM
11/02/10 07:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Homemade progressive linkage on my 392 powered '57 NY.
Re: Pictures of 2x4 carb linkage wanted [Re: John_Kunkel] #844512
11/02/10 09:04 PM
11/02/10 09:04 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
[image][/image]
My 494" Cuda. Note I'm also using 1" spacers under the carbs.
Re: Pictures of 2x4 carb linkage wanted [Re: gtx69] #844513
11/02/10 11:30 PM
11/02/10 11:30 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Stayed as close as factory as I could,it's easy and it works.
Re: Pictures of 2x4 carb linkage wanted [Re: 62maxwgn] #844514
11/03/10 02:50 PM
11/03/10 02:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine is much simpler. A ball stud in each carb. They are connected with a rod threaded internally at one end for adjustment. Sorry no pics. The rod is very similar to the rods connecting factory cross ram carbs to the center bell crank. I like it because its small and not bulky in appearance. Been on the car since 85,no failures.
Doug
Re: Pictures of 2x4 carb linkage wanted [Re: dvw] #844515
11/03/10 06:06 PM
11/03/10 06:06 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Doug
62max's linkage is about the simplest I've seen for a progressive dual quad linkage. But you're right, you don't need anything fance if you don't want a progressive linkage.
Re: Pictures of 2x4 carb linkage wanted [Re: DaytonaTurbo] #844516
11/03/10 09:37 PM
11/03/10 09:37 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What intake & carbs??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Pictures of 2x4 carb linkage wanted [Re: gtx69] #844517
11/04/10 01:00 AM
11/04/10 01:00 AM
AndyF Offline
AndyF  Offline
I make several different linkage kits for dual quad setups. Wedge, Hemi, 5.7, etc.
