Broken Block??? #844507
11/02/10 06:26 PM
11/02/10 06:26 PM
Mashpee,MA
mopar360 Offline OP
Can't start my lawn mower
mopar360  Offline OP
Mashpee,MA
So my car was making this really loud grinding noise for a while. I havent run it in a few months because i was working on pulling the motor, today i took the starter out and Anti-Freeze came out when i took the starter out and the starter was full of it. Any ideas on what this could be? I was thinking a broken block? Any ideas would be great!
Thank you,
Ethan
All throttle...No bottle! 1979 Chrysler 300 (360) 1984 Chrysler 5th Avenue (318)
Re: Broken Block??? [Re: mopar360] #844508
11/02/10 06:44 PM
11/02/10 06:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Must be a small block with a leaking freeze plug in the back
(can't see them without pulling the motor or trans)?
Just a guess
Rich H.
Esse Quam Videri
Re: Broken Block??? [Re: ZIPPY] #844509
11/02/10 08:27 PM
11/02/10 08:27 PM
Mashpee,MA
mopar360 Offline OP
mopar360  Offline OP
Mashpee,MA
Yea its a 360 Magnum. I started pulling the motor last week but because of school its taken me a little bit longer so all i have left is to separate the trans from the motor and pull the motor. So i figured id take the starter off and thats when all the Anti Freeze came out and i literally dumped the starter out and it was FULL of it. Im just hoping my blocks okay. Ill check all the freeze plugs when i pull it.
Thanks,
Ethan
