Pitman arm steering shaft repair sleeve? #844346
11/02/10 03:44 PM
11/02/10 03:44 PM
MOORE OK
AJRR Offline OP
AJRR  Offline OP
MOORE OK
Is there a repair kit or just the sleeve for a 70 B Body Pitman arm power steering shaft. Or is this a waste of time and it is easier/safer to replace the entire gearbox assembly?
Re: Pitman arm steering shaft repair sleeve? [Re: AJRR] #844347
11/02/10 03:50 PM
11/02/10 03:50 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
There is a lower bearing in there. And they sell the seal.
I assume the output shaft is moving laterally.
Re: Pitman arm steering shaft repair sleeve? [Re: autoxcuda] #844348
11/02/10 04:33 PM
11/02/10 04:33 PM
MOORE OK
AJRR Offline OP
AJRR  Offline OP
MOORE OK
Haven't checked for this condition, just have a small static leak. Tried Lucas stop leak, did not work yet, if it ever will.
Just thought a sleeve repair would be easier than replacement.
Re: Pitman arm steering shaft repair sleeve? [Re: AJRR] #844349
11/02/10 04:40 PM
11/02/10 04:40 PM
So Cal
So Cal
Check for movement and change the seal.
