Re: 74 Roadrunner Brake Issues
[Re: indytex96]
#843421
11/01/10 11:57 AM
11/01/10 11:57 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Pedal linkage to tight or binding?
[Re: WILD BILL]
#843422
11/01/10 05:43 PM
11/01/10 05:43 PM
RapidRobert
booster/check valve prob but I would 1st split the booster/mc & check the pushrod clearance to the bottom of the piston recess, want ~1/8", maybe a bit less
[Re: indytex96]
#843428
06/19/11 10:36 PM
06/19/11 10:36 PM
RapidRobert
If your prop valve has it it'll b a little pin w a rubber boot. If so might need to pull/hold it out so the fronts will bleed
[Re: DoctorDiff]
#843431
06/22/11 04:41 PM
06/22/11 04:41 PM
RapidRobert
I'd start back at the beginning and get (2) brass inverted flare plugs from the Edelman" fittings cabinet at your parts house. They're cheap and the end will have an inverted flared "cone" a mirror image of the brass seat(s) in the M/C ports. Cap the M/C & if it good (& bled out) the pedal will b rock hard w virtually no travel. this'll elim the M/C & you can concentrate on the prob valve (blockage of some sort) or one of the 4 corners. "air"
[Re: RapidRobert]
#843432
06/22/11 08:26 PM
06/22/11 08:26 PM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
Are the rear brake shoes adjusted properly?
The Blue Goose
My instagram: Bossride
[Re: indytex96]
#843433
06/22/11 10:12 PM
06/22/11 10:12 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Is the rod in the booster adjusted properly?Thats the first thing to check if you dont have air coming out of the bleeders.That and make sure the PP valve is centered.Rocky
Chrysler Firepower
