Loosing lash on one valve........ Ever had it? #843277
10/31/10 11:51 PM
10/31/10 11:51 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Run the valves the other day before running the car on Wednesday at HC. #4 exhaust valve was tight. I checked all others and reset #4. Made 4 passes and the car fell off .015 in the 1/8 mile on the last pass. Pulled valve covers off and checked lash again. #4 exhaust valve had NO lash left. All .026" were gone. Only thing I can think off is I have a valve getting ready to break (stretching or tullipping the head) or I have a seat beating itself around in the head. I figure if it was lifter or the cam the lash should get larger not smaller.
Quick run down on combo. 440 block, stock lifter bores, comp roller cam, comp roller lifters, Smith Brothers pushrods, Harland Sharp 1.6 rockers, K-motion springs 245 on the seat- 690 over the nose. Indy 440-1 heads with indy valves.
When I found all the lash was gone I set it again and rolled the motor over(not fired)a couple of times and it was gone again. I just put it away and will inspect this week. I already had planned on pulling it for the winter and doing some work anyway, so now there is a reason. I am just glad I caught it before major damage was done. Anyone else ever have this happen.
Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843278
10/31/10 11:53 PM
10/31/10 11:53 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
check the pushrod!
Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843279
11/01/10 12:49 AM
11/01/10 12:49 AM
Take both heads off and inspect them carefully
Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843280
11/01/10 12:49 AM
11/01/10 12:49 AM
Out West
408strokerdart Offline
Out West
I think you are on the right track with your first guess. I bet that valve isn't long for this world. Once they start to stretch the metal will yield easily and continue to loose lash until it seperates. I would say you saved yourself some coin by not running it. Interested in what you find though.
Re: Loosing lash on one valve........ Ever had it? [Re: 408strokerdart] #843281
11/01/10 01:01 AM
11/01/10 01:01 AM
New York
polyspheric Offline
polyspheric  Offline
New York
X2 - the valve head is tuliping, seat receding, etc.
All other changes (rocker tip, pushrod ball, cam lobe) will increase lash.
Boffin Emeritus
Re: Loosing lash on one valve........ Ever had it? [Re: polyspheric] #843282
11/01/10 01:14 AM
11/01/10 01:14 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
If you are loosing lash you definitely soounds like you are having a valve/seat/head issue. Time to investigate further for sure
Re: Loosing lash on one valve........ Ever had it? [Re: Al_Alguire] #843283
11/01/10 08:38 PM
11/01/10 08:38 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I am going out to the shop tonight to pull the engine. I will soon know whats up. I was just curious if anyone else has had a similar problem. I am about 99% sure I will find a bad valve/seat on that head.
Now, just asking as I bet I will be in the market for valves in the very near future. Ferrera, Milidon, etc. Who has the best prices on a good valves. Beep
Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843284
11/01/10 08:58 PM
11/01/10 08:58 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Nice catch John ! That coulda been real ugly.
Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843285
11/01/10 08:59 PM
11/01/10 08:59 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i would think the installed height growing would be noticable. i cant wait to hear the results
Re: Loosing lash on one valve........ Ever had it? [Re: sixpackgut] #843286
11/01/10 09:32 PM
11/01/10 09:32 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Pull the rocker shafts and run a straight edge across the valve tips. I'm interested in what you find.
Re: Loosing lash on one valve........ Ever had it? [Re: Bigcube] #843287
11/01/10 09:57 PM
11/01/10 09:57 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Worn roller lifters can be an issue too.
Re: Loosing lash on one valve........ Ever had it? [Re: camastomcat] #843288
11/02/10 12:29 AM
11/02/10 12:29 AM
Worn roller lifters and cam lobes make the lash get bgger is what I have found on my junk when they went bad Not tighter
Beep, I would and do use Ferea or Manleys, never Milidon again
Re: Loosing lash on one valve........ Ever had it? [Re: Cab_Burge] #843289
11/02/10 10:13 AM
11/02/10 10:13 AM
ohio
flynbyu Offline
flynbyu  Offline
ohio
I would look at the keepers and spring retainers..maybe its knockin the keeper lands off the valve stem.....
Re: Loosing lash on one valve........ Ever had it? [Re: Cab_Burge] #843290
11/02/10 11:22 AM
11/02/10 11:22 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Not nessesarily, they can get bound up if the needle bearing is floating in the bearing body. I'm not saying that's what it is, but I have seen worn out lifters go both ways, tight and loose, but more loose than tight.
Re: Loosing lash on one valve........ Ever had it? [Re: camastomcat] #843291
11/06/10 04:57 AM
11/06/10 04:57 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Well, tore the top end off the engine the other night. It is a lot better than I was expecting. It comes down to a "stupid human trick". A while back I pulled the rockers and checked a suspect spring problem on another cylinder. While reassembling the valve train I accidently tightened down the rockers with the pushrod out of the lifter cup on #4 exhaust valve lifter. After finding it and replacing a bent pushrod, I reassembled it correctly. Unbeknownst to me, I damaged the top of the lifter. It swelled the lifter at the top edge. My losing of lash was caused by the lifter just barely sticking in the bore. Weird thing is, I had checked the valves 2 times since than and never seen any issues with lash. When I pulled the head and found nothing wrong with the valve or seat, I went to the lifters. It was stuck, but not too tight that I couldn't pull it out with 2 fingers. I could also push it in to the base of the cam by hand. So, all in all not too bad. Chalk this one in to the lessons learned column. Thankfully the roller and camshaft have no damage.
Beep
Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843292
11/06/10 05:24 AM
11/06/10 05:24 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Glad to hear it was nothing major and an easy repair
Hows everything else look
Re: Loosing lash on one valve........ Ever had it? [Re: roadhazard] #843293
11/06/10 05:25 AM
11/06/10 05:25 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
x2
Mopar Performance
Re: Loosing lash on one valve........ Ever had it? [Re: moparniac] #843294
11/06/10 08:30 PM
11/06/10 08:30 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Thanks guys.
Greg, really haven't tore into the short block yet. Bores all look good though. Need to get the car back in the trailer to free up some space and then get a plan together for this winter. Beep
Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843295
11/06/10 08:45 PM
11/06/10 08:45 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Good job on the catch. That could have turned ugly real fast. I think one of the hardest jobs for a racer to do is to load up their car because they fill something isn't right.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Loosing lash on one valve........ Ever had it? [Re: pittsburghracer] #843296
11/06/10 09:59 PM
11/06/10 09:59 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I'll be honest. The money I have in the roller valve train and as hard as I spin it, it scares the crap out of me. When I first put it on alcohol this summer, I was a mess when I fired the car up. All of a sudden the car was quieter and I could hear noises in the valvetrain that on gas I couldn't. Now when I lean the fuel out, it goes right back to its snotting self.
Beep
