360 horsepower #842354
10/30/10 10:06 PM
10/30/10 10:06 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
I have a 360 bored 60 over, x heads with 3 angle valve job, 508 lift hydraulic cam, 650 double pumper carb. anyone know about what kind of horsepower ill have out of this. thanks
Re: 360 horsepower [Re: cole63b] #842355
10/30/10 10:28 PM
10/30/10 10:28 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
350ish. Stock type piston?
Re: 360 horsepower [Re: goldmember] #842356
10/31/10 12:29 AM
10/31/10 12:29 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
What compression ratio, that is critical (to guess is pretty useless, has to be measured to accurately figure horsepower). If you have stock style dished pistons, close to .10 below deck, your compression ratio will be about 8:1 at best, and your hp would be 330 or 340 hp.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 360 horsepower [Re: cole63b] #842357
10/31/10 03:33 AM
10/31/10 03:33 AM
low 300's
Re: 360 horsepower [Re: RapidRobert] #842358
10/31/10 02:01 PM
10/31/10 02:01 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
His info is vague AND I am not an engine builder but my observations: Lets assume the OP engine is using the oem pistons. They will be really low on compression. Then that engine has a really large cam. (508 lift...235ish deg @.050??) If this is accurate this would make for a real slug of an engine. I cant imagine such an engine out running the 1972 340 magnum which was 8.5:1 and rated at 240hp. My 360 will have KB107 pistons, OEM LA heads and an Engle 230 degree cam. I will be happy with 350 crank hp.
Keep old mopars alive.
Re: 360 horsepower [Re: 2boltmain] #842359
10/31/10 02:22 PM
10/31/10 02:22 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You are dead on that the info given is vague. The potential low compression will kill the bottom end and make a pooch out of it,with enough converter and gear it may run well enough for the op. That cam is close to 250@.050 and very long seat to seat. Yes, I have run combos like this 20plus years ago and they are not close to ideal.
Re: 360 horsepower [Re: goldmember] #842360
11/01/10 12:47 PM
11/01/10 12:47 PM
P
Paul_Fancsali Offline
P
I'm big on 360s but if that is a stock comp engine as stated it will be a dog. Horsepower roughly 250-280 maybe, decent comp and good stall and or stick it maybe a real good runner. That cam is too outdated to be a real runner compared to the new one out there, I know I ran one for close to 20 years a Racer brown model great with 11.0 comp but still a real dog down low. Stick 4.10s but great mid range and top end. With a lot milder cam I have both low and top end and a good idel to boot, Byb the way thay cam is a gas hog
Re: 360 horsepower [Re: Paul_Fancsali] #842361
11/01/10 01:48 PM
11/01/10 01:48 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
So many here seem to under estimate the output of the 360 and I don't know why. My own experience and that of others around here find that it really don't take much to really wake them up even with stock type pistons. The last one I built was .030 over with 485/495 cam with 271/284 advertised duration, 750 Holley and 4.30 gear and 29.5 slick and it would run low 12's all day in the Duster. Many of us have built many of these engines and found like I said it don't take much even with stock pistons. Lotsa low buck builds around that would surprise a lot of you. Both big and small block.
Re: 360 horsepower [Re: MoparforLife] #842362
11/01/10 02:52 PM
11/01/10 02:52 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
but I also think a 509 is way too big with that low of compression. headers, an LD340/RPM/air gap intake,
a 750-800cfm carb, a good valve job, and something like a comp XE268 will be an honest 340-350ish HP. with the low compression, it'll be soft on the bottom end, and will probably want a 3000 RPM stall converter to really wake up.
2017 Grand Cherokee Overland
Re: 360 horsepower [Re: patrick] #842363
11/01/10 03:32 PM
11/01/10 03:32 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Lot's of ways to skin a cat folks. At 3200lbs it only takes 350hp to run 12.00's at 110mph. It's been done a thousand different ways. I've run low 12's with a comp 268he and a MP .509 in the same combo. One wanted more converter and gear to run mid 11's.
Re: 360 horsepower [Re: goldmember] #842364
11/01/10 04:15 PM
11/01/10 04:15 PM
Upper Midwest
Upper Midwest
I was running an out of the box stock LD4B at the time. Stock heads with no porting or gasket matching done.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 360 horsepower [Re: MoparforLife] #842365
11/01/10 05:06 PM
11/01/10 05:06 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I dont think members are being negative or underestimating the 360- We are simply pointing out what prevents any engine by any manufacturer from making impressive power- pistons too far down at TDC! A 360 400 and 440 is soooo far from its potential and so not ideal with those smog era pistons. I understand if one has to run what they got though. If it were me Id have the engine add ons based around those low comp pistons- RV torque cam, stock 4bbl (Performer/Action Plus) intake headers turbo mufflers- ect.
Re: 360 horsepower [Re: 2boltmain] #842366
11/01/10 05:27 PM
11/01/10 05:27 PM
Upper Midwest
Upper Midwest
I am a firm believer that if the 360 had been introduced in '68' rather than the 340 and built to 340 type specs the tables would have been turned. Built and seen built many 360 with stock dished pistons small 265 470ish & lift cams & 1.88 valve heads, (2.02 didn't do a thing in our trials in fact the 1.88 gave/gives more low end) cars in full street trim with 3.91 gears run at least a half second quicker than the stock 340's of the era. (By the way I was there and owned them)
Re: 360 horsepower [Re: MoparforLife] #842367
11/01/10 05:42 PM
11/01/10 05:42 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
A few years ago I pondered if I really needed new pistons for my 360 project. Id like an honest 350-370 crank hp. I read that many achieved this power level with oem smogger pistons. In the end I did buy a new set of KB107s. They are advertised as a 10:1 piston. I paid $150 for them- brand new but from a moparts member who changed projects. I know the 275hp 340 ran so much harder than the 360 that replaced it and the most significant difference was the piston height.
Re: 360 horsepower [Re: 2boltmain] #842368
11/03/10 09:08 AM
11/03/10 09:08 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Just add a point of reference to this discussion. My 360 is 30 over with zero decked KB107 pistons. I have stock magnum heads and run a Comp XE268H cam (224/230 @ 50, .509/.512 lift with the magnum 1.6 rockers). I have a high rise dual plane intake, 600 CFM vac secondary holley, 1 5/8 headers, A833OD and 3.55 gears.
This combo is making approximatley 370 HP based on 102 mph trap speed.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: 360 horsepower [Re: dgc333] #842369
11/03/10 05:11 PM
11/03/10 05:11 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
This is encouraging for me and my future 360 build. This project of mine is at least 3 years away yet and I really hope to be able to buy the EQ Magnum type heads or the Hughes Magnum type heads. Under my bed I have new KB107s, an Engle cam 230 dur 510 lift and a new Offenhauser 2 x 4 underhood dual 4bbl intake.
Re: 360 horsepower [Re: dgc333] #842370
11/03/10 06:03 PM
11/03/10 06:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Just add a point of reference to this discussion. My 360 is 30 over with . I have stock magnum heads and run a Comp XE268H cam (224/230 @ 50, .509/.512 lift with the magnum 1.6 rockers). I have a high rise dual plane intake, 600 CFM vac secondary holley, 1 5/8 headers, A833OD and 3.55 gears.
The key phrase: zero decked KB107 pistons
That makes all the difference.
If he's running a 509 cam and low compression, it's going to be a PIG. Without compression and a matching intake that cam won't do anything but make him beat his head against the wall.
I remember running a MP 509 cam in my 8:1 440 with a Performer intake. It was horrible. The car had trouble doing a burnout with the stock converter. Once the engine was over 3000 rpm it would start to pull. The intake held it back on the top end.
- Stu Harmon
Re: 360 horsepower [Re: dgc333] #842371
11/03/10 06:50 PM
11/03/10 06:50 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Unless that Abody weights 4500lbs it should run alot more mph if it's making 370hp. When I ran 110mph@3100lbs with a 268he cam and pistons a mile in the hole I guessed it made 325hpish,seems close. what hp would it take to run 107mph @3500lbs? I'd guess 360ish? Maybe I need a better calc.
Re: 360 horsepower [Re: goldmember] #842372
11/03/10 07:15 PM
11/03/10 07:15 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Unless that Abody weights 4500lbs it should run alot more mph if it's making 370hp. When I ran [Email]110mph@3100lbs[/Email] with a 268he cam and pistons a mile in the hole I guessed it made 325hpish,seems close. what hp would it take to run 107mph @3500lbs? I'd guess 360ish? Maybe I need a better calc.
At 3500 lbs it takes close to if not over 400. I was running 103 at 3550 and according to the wallace calculator I was right at 360/370 if I remember correctly.
Re: 360 horsepower [Re: Baxter61] #842373
11/03/10 07:18 PM
11/03/10 07:18 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
on the dyno my 360 made 297 hp at the wheels and went 12.56 @106 - 108 was my best mph ever
small valve heads, air injection ports, with KB 107's and a mopar 474 cam
