Rear brake issues.... #841677
10/29/10 07:53 PM
10/29/10 07:53 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
Im in the process of replacing the brake lines for the rear brakes. first, is there a trick to getting the old brake lines unscrewed from the dist block on the rear axel? Second, if not, is there someplace i can buy a new one? Third, can someone post a pic of what the rear drum brakes on a '70 B-body are supposed to look like. Im having issues, how it was done on the car and what it says in the book are two different things, i just want to see what it is supposed to look like on a car, thanks.
Re: Rear brake issues.... [Re: mkbubs] #841678
10/29/10 07:59 PM
10/29/10 07:59 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
use a line wrench on the brake fittings otherwise you'll probably round them off
Re: Rear brake issues.... [Re: chache876] #841679
10/29/10 08:24 PM
10/29/10 08:24 PM
BDW Offline
BDW  Offline
Soak them with some PB Blaster or something similar. I eventually had to take vise-grips to mine to break them free. I was replacing the lines aways so I didn't mind mangling them.
Re: Rear brake issues.... [Re: BDW] #841680
10/29/10 08:53 PM
10/29/10 08:53 PM
BDW Offline
BDW  Offline
Re: Rear brake issues.... [Re: mkbubs] #841681
10/30/10 01:44 AM
10/30/10 01:44 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If you are replacing the lines, simply cut or break off the old line and use a 6 point socket on the fitting, Pb blaster and a propane torch may help..
It works much better than the line wrench if you are going to replace them.
Re: Rear brake issues.... [Re: sthemi] #841682
10/30/10 09:40 AM
10/30/10 09:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree cut the line and use a 6 point socket.I usually used my 3/8 inmact turned way down and they almost always spin right out.The block is part of the rear hose on my 65 it is. I believe and any good parts store can get them.Rocky
Chrysler Firepower
Re: Rear brake issues.... [Re: BDW] #841683
11/08/10 08:27 PM
11/08/10 08:27 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
Thanks, yeah the cable on the right side, neither side of my rear brakes had that, but the book was showing that it was supposed to have it. The picture in the book wasnt real clear, couldnt exactly tell what was going on.
Re: Rear brake issues.... [Re: mkbubs] #841684
11/08/10 08:32 PM
11/08/10 08:32 PM
Under My Car
Mopar_Country Offline
Under My Car
Napa should have a kit to cover all the little pieces, I'm not sure if the adjuster cable is in there though it might be a separate piece.
Re: Rear brake issues.... [Re: mkbubs] #841685
11/08/10 08:35 PM
11/08/10 08:35 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Not exactly. That pic shows the driver side. The passenfger side wpuld be a mirror image.
The adjuster cable goes to the rear of the car
Re: Rear brake issues.... [Re: Mopar_Country] #841686
11/08/10 08:36 PM
11/08/10 08:36 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
You would need to buy a self adjuster KIT to get the cables and the rest of the hardware.
there is a RH and a LH kit.
Re: Rear brake issues.... [Re: WILD BILL] #841687
11/08/10 09:03 PM
11/08/10 09:03 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Rock Auto has those parts, and they're actually reasonably priced.
