440 overheating questions...
#841393
10/29/10 01:39 AM
10/29/10 01:39 AM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
So I've been trying to chase down an overheating gremlin since I've gotten my Ramcharger on the road. Looking for a little (read: lot) help now. Here are the basic facts: I've got a cheapo Equus electronic temperature gauge and am using their sensor. It is in the 3/8" fitting closest to the water neck in the pump housing. Thermostat is new (so therefor could be deficient) I am using a Ford Taurus electric fan. It moves a lot of air, but is not appropriately sized for my 26" radiator. The shroud is about 5-6" too narrow from side to side, and roughly the same from top to bottom. That leaves a rather large area of the radiator unattended. I know this is an issue, but I can't judge just how much of an issue it is. My timing is currently 14* initial, 40* total. I am not sure when it is all in at. Upper and lower radiator hoses are new. Upper has a spring in it. Lower does not. At idle, with engine up to operating temp, hoses do not collapse with engine revved. Carb is an edelbrock 1406 and IMS are set at exactly 1.5 turns out. Exhaust does not burn your eyes out or smell overtly like fuel, but it does have that tell-tale "carbed" smell. I was doing some freeway driving tonight (65-70 mph) and the temp gauge just kept on climbing. I stopped driving right when it crested 215*. I'm fairly confident it would have continued to rise. I pulled into the house and let the truck idle for ~15 minutes and it dropped, but never going below 200* I do not hear any detonation at speed, but it's an open cabin in there without carpet or flooring, so a 440 in those conditions is pretty loud. When I remove the radiator cap (new Stant 16PSI), I can clearly see fluid moving from the top inlet across, so there is some transfer happening. Water pump "looked" fine, and is the solid cast edelbrock style. I'm not sure if it matters, but my heater hose nipples are plugged. I do not have a loop between the two, they are just capped at their outputs. After continuous driving, if I try and squeeze the upper radiator hose it feels pressurized. Very rigid and firm. If I lift the lever on the radiator cap, I hear a hissing sound coming out of the hose I've got attached to the nipple on the neck of the radiator that is just air. Then the top hose can be squeezed and manipulated. Even though I've got a hose and hose clamp on the nipple in the middle of the radiator neck leading down near the steering box, there is still usually a small ring of fluid around the bottom of the neck. I'm not sure if this is a leak and not allowing the system to build pressure. I ran the engine with straight hose water while I was doing some tuning and testing, maybe 2 months, before draining it and going with an appropriate coolant mix. Now, the coolant has a dark green/brownish tint to it, but no oil on the surface of the coolant in the tank. I'm sorry that was long. I just try to put all the facts that I know out there so some of you felluhs can give me the best answer on where to go from here. I would greatly appreciate it. Thanks for your time -Pat
Re: 440 overheating questions...
[Re: gtx69]
#841396
10/29/10 02:02 AM
10/29/10 02:02 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
You do need a spring in bottom rad hose.When the hose is being sucked close it is at higyway speeds.
I wasn't sure if there was a difference between driving at 2200 RPM and letting it sit in the driveway with me revving it that high. When it's just parked, revving to the same RPM as highway driving, it does not collapse.
Which side of the rad do you have the fan mounted on?
Fan is mounted on the engine side, as it is a puller. When it kicks on, you can definitely feel it moving a lot of heat away from the radiator, inward toward the bay and not outward.
Fan doesn't matter at highway speed when does it come on what temp?
I figured it shouldn't matter. Like I said, I was doing 65 and while we don't have ultra low temperatures here in the desert, it was still in the high 70s at the time. Fan kicks on at 160*
Are you sure your gauge is reading correctly.
I am not sure. I only have one gauge and haven't tried another known good gauge. If I were to get a non-contact thermometer and shoot it at, say, the water pump housing, would that give me an accurate coolant temperature reading? Would a mechanical gauge be more accurate? Is there a way to test my sending unit and gauge? Maybe a pot of boiling water?
Thanks for the reply
[Re: Jeremiah]
#841397
10/29/10 02:19 AM
10/29/10 02:19 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
I would back the timing off to 34 and give it a shot. Especially if you are running 87 octane pump puke. Also, I'd ditch that little fan and get something that covers the radiator.
If my dist is putting 26* in, that would get me down to 8* initial. Is that suitable for a big block in a heavy truck? I'll give it a shot.
[Re: Pat_Whalen]
#841398
10/29/10 05:01 AM
10/29/10 05:01 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
How's the radiator? Is it the correct radiator for the 440, and is it clean inside, or is there crud that might be restricting flow?
I had the same issues with my Cuda after rebuilding the 360 in it in 1995. The temp would slowly rise while cruising down the highway, and would level off and slowly drop at idle. I replaced the radiator with a new 2-core radiator, and that helped - I didn't have to pull over to let it cool anymore - but I was still on the ragged edge of overheating on the highway. About a year later, I had an accident that pushed the radiator into the fan, so I opted to upgrade to a 3-core radiator (and had it paid for by the other guys insurance), and I haven't had a cooling problem since.
By the way, I also have a Taurus fan - it seems like a good unit and moves a lot of air. With the 3-core radiator, though, it almost never comes on. I have it set to come on at about 200 - 205 degrees, and the only times it will come on is if I'm in stop and go traffic or idling for a while.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: Evil Monkey]
#841399
10/29/10 09:23 AM
10/29/10 09:23 AM
RapidRobert
(1) partly restricted stat not opening all the way (toss it for (1) day & check it at highway speed again). (2) inadequate radiator
[Re: DennisH ]
#841401
10/29/10 10:18 AM
10/29/10 10:18 AM
Posts: 15,487 Florida
scratchnfotraction
could be timeing and a lean carb i like to use a vac gauge along with a timeing light write down your seting and try it a few times at diff setings,adjust curb idle and A/F screws to get highest idle i know where to set the SB for cheap gas and where to set it for 92 gas and 1/4 mile blast and no pinging on the rad replacement,have yours flow tested at a red shop,put a recover tank on it and make sure you have the correct cap for a recover system I like the 3/4 ton HD cooling 3 core rads in all my trucks,tey are taller and thicker find a 7 bade fan(got mine from a 76 amc hornet) and get a new NAPA HD cooling thermo clutch with the correct fan shroud you need the spring in the lower hose,you cant see it some time reving it up,but going down the road at sustained rpms it can slowly colapes with a recov sytem it will push water out of the rad as it expands and suck it back in when it cools down add a loop on the heater nipples with a flush tee and back flush it add distilled water and water wetter good luck
[Re: Pat_Whalen]
#841404
10/29/10 11:23 AM
10/29/10 11:23 AM
scratchnfotraction
did you flush the block with the core plugs out?
maybe airflow with the fan set up,i would run a stock thermo clutch 7 blade fan stock shroud
is it a stock BB rad?...heavy duty cooling
I know for my 85 SB I swaped in a 86 3/4 ton SB HD rad and shroud thats taller and thicker 3-4 core
i will be getting another for my 440 also
use candy thermo in the top of rad after its warmed up good and check water temps
does it puke water? on shut down
my 440 ran warm when i first got it running,me setting timeing by ear had it way advanced and carb was lean
got it dialed back and the carb adjusted some and idle down to 650-750 rpms
temp is steady at stat 180*
IMO,I would go as much stock set up as I could and ditch an elect fan for cooling
[Re: Crizila]
#841407
10/29/10 02:18 PM
10/29/10 02:18 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Where does one find a new, suitable radiator? Like I said, this radiator I've got is billed as a 3 core. Shouldn't that be enough? This isn't a high HP application, either. 8:1 with an RV cam.
[Re: Pat_Whalen]
#841408
10/29/10 04:54 PM
10/29/10 04:54 PM
Posts: 7,506 Az
Crizila
Az
Typically, if you can't hold temp at speed, the rad is too small. Definitely, check out the other stuff mentioned. If all is good, rad's too small. Keep in mind when you buy multiple core rad's, the heat transfer really drops off after the second core - something like 50% for the 3rd core verses the first core. Thats why aluminum rads are so much more efficient. Most only use two large ( 1/2")cores. Can't do that with brass as it's just not strong enough. You probably need a rad with more surface area.
Fastest 300
[Re: rhad]
#841410
10/29/10 08:06 PM
10/29/10 08:06 PM
Posts: 10,210 Someplace you aren't
SomeCarGuy
You need to recurve the distributor. 40 total is too much. An 8 to 1 motor has no quench. 34 would be good, might could run 36.
I ran my car at 38 total and I never heard it ping. Just didn't run as smooth as at 34. Tried 36 and wasn't much different than 38. More than likely it had some silent knock at the higher settings. Back to 34 and it is smooth once again.
3 core might not be doing the job.
Running it on straight water may have started a rust fest in there.
I want my fair share
[Re: SomeCarGuy]
#841411
10/29/10 08:51 PM
10/29/10 08:51 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Decided to try and eliminate some of the questionable variables. Went to the local parts store and picked up a mechanical temp gauge. Brought it home, put it in a pot of boiling water along with one my digital thermometers and it was dead nuts on. Took it and installed it in the other vacant 3/8 port on the pump housing next to the electric temp sending unit. Went for a quick jaunt down the road. As predicted, electric gauge got up to 210* but mechanical only hit 195. Pulled into the driveway and was able to relieve system pressure and take off radiator cap. Put my thermometer in there about an inch under the coolant level and it read 195*. I'm running a milodon 160* thermostat. I'm going to try backing down the timing a bit more. At idle, with vacuum unplugged from the dist, I'm getting 12*. I plug in the vacuum line and it jumps to probably 20*. I have my idle set at roughly 800. Thanks for all the help so far, folks.
