Temperature sending unit options on big block?
#840652
10/28/10 01:08 AM
10/28/10 01:08 AM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
I'm shopping for all the pieces of my megasquirt changeover on my 440 and the recommended pieces for temp sensing is a chevy part that is 3/8" NPT. Is there any option for 3/8" npt on the engine anywhere? I know the port on the water pump housing is 1/8" NPT. As a followup, is the temp port on the top tank of the radiator a reliable spot for temp sensing? I've got my temp sensor in there now and it seems like it might be reading a bit high, although I have nothing to compare it to. Today I was cruising around and it started pushing 210-220. I got under the hood and started checking around and feeling hoses to see how pliable they were. The top hose that should be going to a catch can (it's not) wasn't running any coolant out of it, and when I lifted the relief on my rad cap, there was a pressure let-off, but nothing catastrophic. Thanks all -Pat
Re: Temperature sending unit options on big block?
[Re: Pat_Whalen]
#840653
10/28/10 02:22 AM
10/28/10 02:22 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Some water pump castings have an normally unused pipe plug in the top, by the heater hose tubes, that would be the best place.. Some C body models use a large switch with two spade terminals to make the cold and hot light work, and that is the place for that sender. I think the radiator would rear a little high, but should be in the ballpark..
[Re: sthemi]
#840654
10/28/10 09:35 AM
10/28/10 09:35 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Most all have them , I'm pretty sure there is at least one extra maybe 2 .
