whats the best way to seal an iron 360 intake? #840627
10/27/10 11:34 PM
10/27/10 11:34 PM
Clinton Twp. Michigan
coronet1966d Offline OP
i had a real bad intake leak on my 360 and im looking to replace the gaskets with something better, what have you used and what works best?
do you guys use the cork ends or use the right stuff?
Re: whats the best way to seal an iron 360 intake? [Re: coronet1966d] #840628
10/27/10 11:55 PM
10/27/10 11:55 PM
Under My Car
Mopar_Country Offline
Under My Car
I used the FelPro set on my smallblock, sealed perfectly. I did use the cork on the ends, I ran a bead of sealer and set the cork on there, weighted them down, and let it set overnight. Next day I sealed the water ports on both sides of the gaskets, applied another bead of silicone on top of the cork and carefully set in place. If the pins are there just need to be sure they line up with the holes in the intake or remove them.
Re: whats the best way to seal an iron 360 intake? [Re: Mopar_Country] #840629
10/28/10 01:28 AM
10/28/10 01:28 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
fel pros with no gaskets on the ends, just some goo.
Re: whats the best way to seal an iron 360 intake? [Re: coronet1966d] #840630
10/28/10 10:44 AM
10/28/10 10:44 AM
Chicagoland
JohnnySivilian Offline
Chicagoland
try the felpro performance gaskets. My customers have had good luck with them on brand x. p/n 1213 is a composite gasket .060 thick for 360 with 1.16 x 2.27 ports.
