Pistons for 360 #840087
10/27/10 08:25 AM
10/27/10 08:25 AM
New Brunswick, Canada
CoyoteJack Offline OP
I am in the planning stages of building a 5.9 magnum with a 6/71 on top. I was wondering if anybody else had built a 5.9 whether it be blown or turbo'd. If they have, what pistons did you use? I am trying to get down to 8 to 1 compression with Magnum heads.
Jack
Re: Pistons for 360 [Re: CoyoteJack] #840088
10/27/10 09:46 AM
10/27/10 09:46 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Best bet are to run some custom pistons so you can move your rings lower and get any compression height you desire. I run JE.
Re: Pistons for 360 [Re: TheOtherDodge] #840089
10/27/10 12:58 PM
10/27/10 12:58 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
Ross custom here...8:1 comp with a x-head..ceramic coated tops all for around $500
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Pistons for 360 [Re: dodge turbo] #840090
10/27/10 01:59 PM
10/27/10 01:59 PM
That seems like a pretty good price.
Jack
Re: Pistons for 360 [Re: CoyoteJack] #840091
10/27/10 05:54 PM
10/27/10 05:54 PM
Houston, Texas
Houston, Texas
WOW! $500 for a blower piston with coating? Did you get some sort of special deal?
Coating tops for a set of pistons is about $120 + pistons!
Re: Pistons for 360 [Re: TheOtherDodge] #840092
10/27/10 07:32 PM
10/27/10 07:32 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I was thinking the same thing. Probably more like $1000+ for something like that.
I can tell you to get to 8:1 on a 5.9 with iron heads is going to take a custom piston though.
I'm in the middle of doing a 360 with open chamber '308 heads, and I couldn't get the compression to 8:1 with an off the shelf piston.
The closest thing I could get was a Probe SRS series piston. 14.5cc dish, but even with that you'd need a crazy thick head gasket to get to 8:1
Re: Pistons for 360 [Re: dizuster] #840093
10/28/10 07:50 AM
10/28/10 07:50 AM
That's exactly what I am finding. A friend thought of going with a chevy piston and getting my rods bushed to the chevy pin size, but up here the machinist's want a small fortune.
Jack
Re: Pistons for 360 [Re: CoyoteJack] #840094
10/28/10 09:51 AM
10/28/10 09:51 AM
Houston, Texas
Houston, Texas
My custom JE pistons were $950, + rings. Since custom, I put the ring pack low, 9.3:1 compression with my heads, .927 pin. I bought 6.200 rods with 2.200 journals.
Re: Pistons for 360 [Re: CoyoteJack] #840095
10/28/10 10:03 AM
10/28/10 10:03 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have a 340. 7.9-1 with a 6.25 rod. Venolia pistons were $500 in 1991.
Doug
Re: Pistons for 360 [Re: dvw] #840096
10/29/10 01:32 PM
10/29/10 01:32 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Depending on the cam, the chevy pistons might not work anyway. Valves are in a different location/different angle...
How much boost are you going to try to run with this thing?
I mean you can always get a .120" thick cometic gasket, but they are expensive...
Re: Pistons for 360 [Re: dizuster] #840097
10/30/10 08:23 AM
10/30/10 08:23 AM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Depending on what you want, I can have custom Diamond pistons made. If you go to a full dish design, then up to a 50cc dish is not a problem. I can even do a group buy if I get at least 5 sets of the same piston.
Re: Pistons for 360 [Re: dizuster] #840098
10/30/10 09:25 PM
10/30/10 09:25 PM
I am only looking at running 8 lbs of boost. But you know how that goes. If 8 lbs is good then 10 must be better, and so on. LOL
Jack
Re: Pistons for 360 [Re: todd440] #840099
10/30/10 09:27 PM
10/30/10 09:27 PM
What kind of money are you talking about. By the way I won't be building this until the spring. Just trying to get my head around what is required first.
Jack
Re: Pistons for 360 [Re: CoyoteJack] #840100
10/31/10 08:56 PM
10/31/10 08:56 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Are you trying to run this thing on pump gas? Even so, I wouldn't be afraid to run 8~10psi with a 6-71 at 8.5:1. You could get there with the Probe's that I mentioned above. The top ring is .320" down from the crown as I remember. So not a bad choice for a blower piston...
With a splash of race gas, you could run even more if you wanted to "turn it up".
Re: Pistons for 360 [Re: dizuster] #840101
11/01/10 08:36 AM
11/01/10 08:36 AM
Yes on the pump gas. This is going to be a street engine to replace my current LA/Magnum hybrid. A great working engine but I want the eye candy sticking out of the hood. Not to mention the extra thrills of close to 600 HP and TQ. Do you have a part number for that probe piston? I would like to check it out.
Jack
Re: Pistons for 360 [Re: CoyoteJack] #840102
11/01/10 03:39 PM
11/01/10 03:39 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Sure, no problem...
http://www.probeindustries.com/Chrysler_360_14_5cc_Reverse_Dome_SRS_Pistons_p/12351.htm
I got them from www.cnc-motorsports.com
They were BY FAR the best price. Just call them and tell them what you want to order, it's not on their website.
Re: Pistons for 360 [Re: dizuster] #840103
11/01/10 03:55 PM
11/01/10 03:55 PM
Sure, no problem...
They must have added them to the website since you bought them. Strange that the compression ratio is a little different from Probes site. I would still have to use a thick gasket to get down to the compression ratio I want, but I can live with that.
Jack
Re: Pistons for 360 [Re: CoyoteJack] #840104
11/01/10 04:17 PM
11/01/10 04:17 PM
dodge turbo Offline
dodge turbo  Offline
like i said call Ross they will make you a custom piston for the same price as a shelf piece
Re: Pistons for 360 [Re: dodge turbo] #840105
11/01/10 08:14 PM
11/01/10 08:14 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I'm sorry man... but you can't get a Ross custom made for $499 shipped with pins...
The off the shelf Ross flat top is $100 more then that, and they don't even offer a dished shelf piston from what I see...
How can they be cheaper then that?
BTW... not to hi-jack but Dodge Turbo your truck is awesome... check your PM...
Re: Pistons for 360 [Re: dizuster] #840106
11/01/10 08:24 PM
11/01/10 08:24 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
I'm still waiting to hear back from my Diamond rep for pricing. The way I figure it, at 62cc head, 9.0 cc gasket, ect, you would need a 30cc dish to get you to 8.4 to 1. That's based off of .030 over on a 360, stock stroke.
