Re: BLENDING FUEL
[Re: G_bob]
#840040
10/27/10 10:52 AM
10/27/10 10:52 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
No big deal. It's a linear mixture. 1 gal of the 91 plus 1 gallon of the 110 nets 2 gallons of 100.5 2 gal 91 plus 1 gal 110 = 3 gal of 97.33, etc.
did it for years when I had 12.2 with iron heads 40% 110 60% 94 = 100.4 on the street I would use 94 and turn the total back to 33 and no ping at 38 it pinged fairly good.
Aluminum heads and 11.7 to one and straight 94 nice for a poor retired guy!!!
Re: BLENDING FUEL
[Re: superwrench]
#840043
10/27/10 02:21 PM
10/27/10 02:21 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
if you can get AV gas its only about $4 a gallon here. i mix 5 gallons of AV gas to about 10 gallons of 93 when i go to the track
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: BLENDING FUEL
[Re: 493_DART]
#840045
10/27/10 03:32 PM
10/27/10 03:32 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Is E-85 available in your area?
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: BLENDING FUEL
[Re: Dap]
#840046
10/27/10 05:54 PM
10/27/10 05:54 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I mix 1 gal C16 to 1 gal 97 unleaded for around 12.5 to 1, could i use less race fuel?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: BLENDING FUEL
[Re: sixpackgut]
#840047
10/27/10 07:27 PM
10/27/10 07:27 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
whats the octane on AV? is it hard on rubber lines , etc.. ?
Re: BLENDING FUEL
[Re: Dap]
#840048
10/27/10 07:27 PM
10/27/10 07:27 PM
493_DART
Worst Weather USA
im sure it is , but i cant afford the conversion
Re: BLENDING FUEL
[Re: 493_DART]
#840056
10/29/10 01:30 AM
10/29/10 01:30 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
IMO, theres no doubt that detonation had a key role in kicking out the gasket, once you dropped the jet size in great air.
On the Edelbrock gasket question! Theres a big thread about that in the Archives.
People would spend Extra money to get Edelbrock HD 12.5 + gaskets. They used to be different ,but were replaced with the Felpro 8519pt gaskets, because of availability problems.
Witch you can get for $20 bucs less if you just ask for the FelPro 8519pt gaskets,
What gaskets are you using on this rebuild? If its the 8519pt, I wouldnt be to concerned. mike
