1939 D11S Dodge Bus. Cpe Info ???
#839384
10/26/10 11:03 AM
10/26/10 11:03 AM
Posts: 18 MN
dgas
MN
I was recently offered one of these. Street rod w MII, 289/C4 Ferd Motor and 9", Which in my humble opinion are junk and needs to be changed out for a mopar drivetrain.(except the 9"). It appears that all the hard to find things are there Window Inner Garnishes, Headlight bezels, Taillights, Hood Orn. All in real nice unpitted condition. Anyone ever mount up a 360 ,383 or 440 in one of these? Any info would be appreciated. Mounts ,radiator etc. I am not a beginner, but certainly not a pro.
Re: 1939 D11S Dodge Bus. Cpe Info ???
[Re: dgas]
#839386
10/26/10 09:22 PM
10/26/10 09:22 PM
Posts: 10,644 Freeport IL USA
poorboy
Freeport IL USA
Looks like a decent starting point, except the front tires look awful far back in the wheel openings, might just be the angle of the picture though.
Swapping in a Mopar drive train can be as simple as bolting it up, or as complex as redoing the misplaced or hacked front suspension. Since we have no idea how the Mustang II was done, it could be incorrect and faulty information to list a process of installing the correct drive train.
Originally a 39 Mopar has the same basic independent front suspension as the 41-48 Dodge, Plymouth and Chrysler, so all the info covering them would apply. What has been modified from original will probably alter that process, but it may have made the process easier.
Position the engine and transmission so that they clear the frame and cross menbers, exhaust, steering, and sit at the proper angle to have a level carb. Make mounts as needed, make a drive shaft, and life should be good.
I had a 39 Plymouth business coupe, loved it until I had to sell it to put a motor in my work truck. I'm currently building a 48 Plymouth business coupe. Gene
[Re: poorboy]
#839387
11/26/10 03:39 AM
11/26/10 03:39 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
to me the roof line looks 1940 not 39. 39 dodges have a helemt looking roof like a 40 chevy,
and the hood release on the engine cover side looks chrysler in this pic,,,
also to put a mustang II cross member in a 39 frame,, you have to wack off the front stub,,the 39 and 40 front frame wont except a mustang cross member, but looks like a solid car and i wouldnt pass it up if its a decent car and deal, i havea 40 buss coupe 241 hemi a friend has a 37 with a 413
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: shinnery]
#839394
12/03/10 11:49 AM
12/03/10 11:49 AM
Posts: 34,958 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
That white car is interesting, Chrome wheels w/blackwalls on one side and WWWs on the other. Bryce
It's not white, its pink ..has a older GM v6 in it
