Re: Mini tubbed 69 Sat and rearend size
[Re: Drip]
#839299
10/26/10 09:37 AM
10/26/10 09:37 AM
Posts: 2,648 GA
Boosted
GA
Stock rearend length is fine and use a 6.5BS wheel..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: Drip]
#839300
10/26/10 10:17 AM
10/26/10 10:17 AM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
I've seen guys use the slightly narrower A-body rear end, with redrilled axle bolt pattern, to get a deeper wheel offset with aftermarket wheels.
You'd also have to move the spring perches.
[Re: Dean_Kuzluzski]
#839301
10/26/10 03:40 PM
10/26/10 03:40 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
When I did mine, I had my truck dana cut down to a-body length as I was able to use some used moser axles and got them cheap. I ran 15x10 wheels with around 6" of backspacing. I can;t remember the exact numbers as I lost it all with my old computer.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
