Page 3 of 16 1 2 3 4 5 15 16
Re: Mercedes fan upgrade [Re: gtx69] #838230
11/02/10 02:01 AM
11/02/10 02:01 AM
hooziewhatsit Offline
trinary is pretty simple.
Looked at it some more, and I think I got it figured out.
In the attached image, the red arrow is pointing at the 'relay' in the trinary switch. In this diagram, once the pressure is high enough, it will close and send 12v to the controller.
It sounds like in your case, instead of 12v on the right side, you have it connected to ground. So, once the system pressure is high enough, it would send a ground to the controller. Then I turn the fan on to full speed after a short delay. Does that seem to match how your car is set up? I think I have a design that will work with either a high or low to indicate the AC is on.
If I can get it to turn the fan on when the sensor input is grounded, that sensor you linked should work just fine.
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838231
11/02/10 09:57 AM
11/02/10 09:57 AM
Andrewh Offline
Andrewh  Offline
yes, except the delay part that sounds right.
I meant a delay for it to not shut off.
That is right now the fan short cycles on if the trinary kicks it on.
It turns on and almost immediatly shuts off.
I would prefer a 20 or 30 sec delay before it shuts off again.
problem is moving at speed and wanting the fan off, but that would require a vss signal. that gets too complicated. lol.
Re: Mercedes fan upgrade [Re: Andrewh] #838232
11/05/10 10:03 AM
11/05/10 10:03 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Where's your sense of adventure? We can make this entirely too complicated if we try hard enough.
- Stu Harmon
Re: Mercedes fan upgrade [Re: feets] #838233
11/05/10 10:33 AM
11/05/10 10:33 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
COMON YOU GUYS!! figer sumthin out out us knukel draggers can just bolt up.
Re: Mercedes fan upgrade [Re: bonefish] #838234
11/05/10 11:39 AM
11/05/10 11:39 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Keep yelling and you can continue sticking your knuckles into flex fans.
I have sent an old style fan to him so he can play with the fan controller. We're trying to keep it functional and simple to use with an option or two for use with A/C.
These things are monsters. Running them at full speed would become annoying if you're fiddling with the engine. It would be hard to hear over the fan and the air would be blasting out every possible place over and under the engine.
- Stu Harmon
Re: Mercedes fan upgrade [Re: bonefish] #838235
11/05/10 02:19 PM
11/05/10 02:19 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
My sentiments exactly.
All this talk of PWMs, controllers, relays, etc., is way over my head.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Mercedes fan upgrade [Re: 340727dart] #838236
11/05/10 04:34 PM
11/05/10 04:34 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I was told there would be no math
Re: Mercedes fan upgrade [Re: Pool Fixer] #838237
11/05/10 04:54 PM
11/05/10 04:54 PM
No math on your end
You'll have to hook up power, ground, the temp sensor, and the trigger wire to the fan. Turn two knobs to set the on and full speed temp, and forget it.
I on the other hand... I get to read the two temps you selected, then figure out how to increase the PWM duty cycle linearly from one to the other. The PWM itself is handled in hardware, so I just tell it what duty cycle to generate
But now, at least for my own personal controller, I'm thinking of giving it a temperature (ie, 200*F), and letting the fan vary speed to maintain that temp (within reason of course).
Re: Mercedes fan upgrade [Re: Pool Fixer] #838238
11/05/10 04:58 PM
11/05/10 04:58 PM
Andrewh Offline
Andrewh  Offline
see this is what happens when you listen to grownups talk. just wait and we will tell you when it is done.
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838239
11/05/10 05:05 PM
11/05/10 05:05 PM
Andrewh Offline
Andrewh  Offline
No math on your end
do you actually have a scale on the knobs, or are you guessing?
Do not set the fan to stay on.
when moving it will actually inhibit air flow.
I can tell when I hit the freeway with the fan running, my temps are higher than if the fan is off. That is why I mentioned a speed sensor. To make sure it cuts off when moving.
I have thought of a manual switch before, but woe und to him that forgets to flip it back on when leaving the freeway after a high speed run and gets stuck in stop and go traffic.
Re: Mercedes fan upgrade [Re: Andrewh] #838240
11/05/10 05:43 PM
11/05/10 05:43 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I feel like this right now:
Re: Mercedes fan upgrade [Re: Andrewh] #838241
11/05/10 05:55 PM
11/05/10 05:55 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'm telling your wife that you're stealing her lines!
As for inhibiting air flow at speed, yours seemed to hover right on the turn-on temperature but didn't actually get hotter. Did you have the A/C on? I can't remember what the temp was like outside that day.
When Donnie and I were making pull after pull all night long with the hot rod it didn't heat up. Even the back to back 60-120 mph high gear pulls under boost didn't heat the car.
In fact, I only had heating issues after we wasted the head gasket and were blowing combustion gasses from #8 into the cooling system.
- Stu Harmon
Re: Mercedes fan upgrade [Re: feets] #838242
11/05/10 06:18 PM
11/05/10 06:18 PM
Andrewh Offline
Andrewh  Offline
it hangs out a few degrees warmer than not running, not passes down the road.
driving at 70 mph won't over heat, but the fan will never shut off due to the temp difference.
mine comes on at 205 and shuts off at 195. My best guess is it sat at around 210 instead of sitting on the thermostate at 195 or just under when the fan is off. This is only based on the gauge differences.
It is a shorter run to the freeway leaving your house then leaving mine. so leaving yours it is always cooler than when leaving mine even if the outside temp is about the same.
Re: Mercedes fan upgrade [Re: Andrewh] #838243
11/05/10 09:12 PM
11/05/10 09:12 PM
The knobs will have a scale, and after doing some testing on my end, should be accurate to the manufacturing differences in the temperature sensors (should be very small). Standard disclaimer: all temp gauges will be slightly different, so you may have to make some adjustments to match your gauges.
I'm a bit gun-shy about just turning the fan off when you hit highway speeds. I guess I don't want to assUme that there will be enough cooling. With a temperature sensor, the controller can turn the fan on as needed.
I'll have to think about highway speeds though. Naturally, if the fan is at 90%, and the temp goes up, you don't want to slow the fan. Unless of course the fan is the reason the temp went up, and you actually need the fan to slow down/turn off. Very counter-intuitive.
Or, I could add a button similar to the one on smoke detectors: turn the fan off and ignore the temp sensor for 5 minutes. By then it's cooled off enough the fan doesn't have to turn on.
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838244
11/05/10 11:48 PM
11/05/10 11:48 PM
Andrewh Offline
Andrewh  Offline
I like the momentary button idea.
that would work. that way I don't have to remember to turn it on.
Automatic from a vss would be nicer, but since I won't be using your controler long term, I guess it doesn't matter to me.
Believe me it isn't a guess. The car runs hotter if the fan is on at freeway speeds.
Re: Mercedes fan upgrade [Re: Andrewh] #838245
11/11/10 10:38 PM
11/11/10 10:38 PM
annndd, test results
I got the fan from feets yesterday, and after doing some massaging of my circuit today, mostly got it to work.
I'm driving the fan with a 100Hz signal. The fan will only come on with a duty cycle above ~85%. 90% it comes on, 100% it comes on, etc. I get nothing from 0 to that 85%.
I have a button set up to increment or decrement the PWM value. While decrementing from 100%, once I get below that 85%, I can hear the fan click off. While incrementing, again, above that 85% it comes on. So I don't think it needs a higher value PWM to 'get it moving' before going to a lower one.
I have the fan running off a battery in my office, so I haven't let it spin all the way up to see if there's a noticeable difference in speed between 85% and 95%
Now I'm not sure if this fan's controller is different than the aftermarket controllers, and whether they would work with lower PWM values or not.
Feets, do you know if the mercedes ECU can control a wider range of values than that or not?
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838246
11/12/10 06:11 PM
11/12/10 06:11 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I honestly don't know. I tried digging around on the workshop system but didn't find anything pertinent.
We stock both the new and old style fans. There is a production date split on the two part numbers so the engine controller could have different logic or Mercedes is just being anal again.
The aftermarket fans seem to interchange. Could it be looking for something coming back from the tachometer line?
Feed that beast a 40 amp fuel supply and hit it at 90%. See if it runs for more than 30 minutes. If so, that should do the trick. We'd lose the multi speed thing until you have time to figure that out but it should cool the engines.
My fan is supposed to run at 90% with a constant supply. It cools my engine.
- Stu Harmon
Re: Mercedes fan upgrade [Re: feets] #838247
11/12/10 06:44 PM
11/12/10 06:44 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Wait...
Merciless Bends has a habit of hanging on to their existing stuff and adding to it.
The electric fans used in the 90s had resistors to control the fan speed. That varied the voltage to the motor.
Now, if the engineers left that system alone but jumped to a brushless motor, the controller would pulse variable voltage to the motor.
I have a rudimentary (at best) knowledge of electric motors. I know very little about brushless motors.
Is it possible to test the fan by running 8 volts through the PWM controller?
Andrewh says he got a lower speed with lower voltage to the trigger.
Perhaps I'm way out of bounds on this. I haven't a clue.
- Stu Harmon
Re: Mercedes fan upgrade [Re: feets] #838248
11/12/10 08:10 PM
11/12/10 08:10 PM
Actually, how I have it set up currently, I should be able to give it 8v fairly easily. I'll test it later tonight and give an update afterwards.
Re: Mercedes fan upgrade [Re: hooziewhatsit] #838249
11/12/10 09:34 PM
11/12/10 09:34 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
WOW!!! I was just hoping to get a fan controller here, but I am getting an education to boot. Keep up the brain storming guys.
Master, again and still
