Re: Oil seal-SB timing cover
[Re: Garranimal]
#837849
10/24/10 11:59 PM
10/24/10 11:59 PM
RapidRobert
can i use a bearing driver to drive it back in?
Yes & get it started evenly w a light touch then drive it home w as few strokes as possible as each one greatly increases the chances of distorting it especially as the open face goes to the rear & there's not much contact area. Check that it is still even after each stroke & tilt the driver if needed. EDIT use your biggest hammer
