Re: Barn Find (sort of) '71 Charger SE [Re: Devil] #837546
10/27/10 12:38 AM
10/27/10 12:38 AM
Illinois
SGTFURY62 Offline OP
Illinois
more shots
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837547
10/27/10 12:40 AM
10/27/10 12:40 AM
Illinois
Illinois
side shot
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837548
10/27/10 12:43 AM
10/27/10 12:43 AM
Illinois
Illinois
one more for the night...oh yeah with the interior shot, I have not even cleaned it or wiped it down with anything. Carpet is faded and cloth inserts on seats have some fading but with a little dye will look as new.
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837549
10/27/10 12:49 AM
10/27/10 12:49 AM
Illinois
Illinois
I think I know what grounded car. The left rear 1/4 panel is bent under from the car losing its rear wheel and going under car (this is why I am missing one roadwheel). Car looks like it literally ground to a stop taking with it the rear drum, half the backing plate, most of the lower shock/spring mount on drivers side. It has loose studs stuck in axle to move. It looks like this happened a long time ago. Tags expired in 80's. There is a bag full of brake parts in trunk also where it looks like someone was going to fix it but never got around to it.
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837550
11/05/10 12:35 AM
11/05/10 12:35 AM
Illinois
Illinois
Changed the oil and filter. Ran an new fuel line to a gas can, primed carb and turned over....VROOOOMMM! Fired right up with about 60 lbs of oil pressure and no leaks. Yea!!!! Did not run too long but long enough to blow out a ton of stuff out the exhaust and warm up just a little. sounds great. Heard no unusual noises and ran quiet through its stock single exhaust.
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837551
11/14/10 08:27 PM
11/14/10 08:27 PM
Illinois
Illinois
Have discovered she needs a full 1/4 and outer wheelhouse of ps and both front fenders replaced due to massive salt corrosion. Here's one of the ps with a new fender test fit today.
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837552
11/14/10 08:33 PM
11/14/10 08:33 PM
Illinois
Illinois
Engine is running great now too! Changed out fuel pump due to leaking and cleaning out my engine whew! Changed out oil/filter couple times and put some new fuel lines in also. Ran that Lucas fuel stuff through carb and in a can of fuel and original carb is working great!!!! Engine fires up on first crank and sounds healthy and doesnt overheat and maintains good oil pressure at idle.
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837553
11/15/10 01:59 PM
11/15/10 01:59 PM
Chilly Northern, Minn.
71 Charger R/T Offline
You've gotta be one lucky guy, where'd you find such a nice fender? And an R/T fender to boot! Is there anything else left of the car you got the fender off of?
Re: Barn Find (sort of) '71 Charger SE [Re: 71 Charger R/T] #837554
11/17/10 12:22 AM
11/17/10 12:22 AM
Illinois
Illinois
A buddy of mine had this one and a just as nice drivers side I was able to get off him very reasonably I think. He has about 3 more pairs I think I spotted stashed. The R/T the fender came off of he said had been totaled years ago and the owner parted out what was salvageable.
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837555
11/17/10 12:31 AM
11/17/10 12:31 AM
Illinois
Illinois
Pulled interior out to check floors and found great sheetmetal AND my cars buildsheet. Fender tag and buildsheet verify the V6X stripe now along with the stripe remnant under the repaint. Funny the other cars buildsheet that I found also was coded with the V6X stripe...I wonder if they did a run of these, it was optioned almost exactly like mine as well just a different color. Heres a shot of an r/t that motivated me to go back original with mine...
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837556
11/17/10 08:02 PM
11/17/10 08:02 PM
st louis mo
Q5Bee B5ScatPack Offline
st louis mo
Very cool.Im just curious and have to ask(and i mean no offense)but how did your 7 year old find the car?
1969 SUPERBEE 383 Q5 RED STRIPE WHITE INT.
2015 CHALLENGER SCAT PACK B5 BLUE
1996 INDY RAM PACE TRUCK
Re: Barn Find (sort of) '71 Charger SE [Re: Q5Bee B5ScatPack] #837557
11/18/10 11:33 AM
11/18/10 11:33 AM
Paducah, KY
bigsexy440 Offline
bigsexy440  Offline
Paducah, KY
I found my '73 Charger, and a '73 Roadrunner cruising alleys on my bike back when I was a kid! All kinds of goodies hiding in alleys.
Re: Barn Find (sort of) '71 Charger SE [Re: Q5Bee B5ScatPack] #837558
11/19/10 06:54 PM
11/19/10 06:54 PM
Illinois
Illinois
We were out looking at rental houses for my mother in law and he spotted next door to one of the places we checked out...wife and him went around back of rental place to see how it was and he comes running back to car yelling "Dad there's a Charger back there!" Got the car but not the place. Wife was amazed he knew what type it was...come on dear that's my boy!
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837559
03/19/11 07:37 PM
03/19/11 07:37 PM
Illinois
Illinois
Cut off old quarter and rusted areas and began test fitting new AMD quarter. Fits like a glove.
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837560
03/19/11 07:40 PM
03/19/11 07:40 PM
Illinois
Illinois
Pulled the old 8 1/4 rear out last week and rolled the 8.75 under it too! Here's another shot of the quarter. I still need to cut out some more metal down at rocker in front of tire but fitting great.
Re: Barn Find (sort of) '71 Charger SE [Re: SGTFURY62] #837561
03/23/11 04:49 PM
03/23/11 04:49 PM
Chicago, Illinois
Devil Online penguin-006
Devil  Online Penguin-006
Chicago, Illinois
Looking good. Can't wait to see it out and about.
Re: Barn Find (sort of) '71 Charger SE [Re: Devil] #837562
03/23/11 09:34 PM
03/23/11 09:34 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
Always loved that style, keep up the good work
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
