Re: MPG 318 VS 360
[Re: The Sphinx]
#837387
10/24/10 11:05 AM
10/24/10 11:05 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
At the low rpm you're going to be holding, I'd stuff the 318 in there. For some reason the 360 has never returned the mileage of the 318.
Re: MPG 318 VS 360
[Re: The Sphinx]
#837388
10/24/10 01:07 PM
10/24/10 01:07 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I can't say for 1972 specs, but in Jan of 1997 Popular Mechanics magazine had reader's surveys .. first one on Dodge Rams ... then a few years later on Durangos In the Ram survey, owners reported the 1.8 MPG on the highway better on the 5.2 versus the 5.9 V8s. http://web.archive.org/web/2005103120593...?page=3&c=yI don't have the Durango one bookmarked, but i think the MPG difference was smaller, maybe 0.75
Re: MPG 318 VS 360
[Re: 360view]
#837389
10/24/10 02:51 PM
10/24/10 02:51 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
The 360 has lower compression, bigger cam, bigger ports(slower ports) so the gas miledge will be even a bigger differance than the magnum motors that share the same heads with just slightly different cams and compression.
If you built them to similar specs then the differance would be smaller but the 318 would still get better mpg.
Re: MPG 318 VS 360
[Re: The Sphinx]
#837391
10/25/10 09:28 AM
10/25/10 09:28 AM
Posts: 15,487 Florida
scratchnfotraction
360 is bigger bore and longer stroke which suxs more gas ![](/ubbthreads/images/graemlins/whistling.gif) its a no brainer for MPGS ![](/ubbthreads/images/graemlins/shruggy.gif) thats another reason the 318 is called whimpy,smaller bore and shorter stroke is less torque ![](/ubbthreads/images/graemlins/drive.gif) little hoter cam,small 4-v,headers does a 318 good and still gets better mpgs over a 360 stock or built A q-jet works very good on a 318 for MPGS also ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: MPG 318 VS 360
[Re: The Sphinx]
#837392
10/25/10 09:29 AM
10/25/10 09:29 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
why build to factory specs? I'd copy hotroddave's super duper MPG 318 build, or if you want a hydraulic cam, I'd start with a magnum 318, use KB167's at 0 deck, and run a reground cam with bullet cam's HR259/316 lobe on both the intake and exhaust. http://www.bulletcams.com/Masters/HRlobes.htm
Re: MPG 318 VS 360
[Re: scratchnfotraction]
#837393
10/25/10 02:12 PM
10/25/10 02:12 PM
Posts: 591 Champion City
The Sphinx
Champion City
That is why the question asked is what would be the difference, implying that there would be a known difference
Re: MPG 318 VS 360
[Re: patrick]
#837394
10/25/10 02:13 PM
10/25/10 02:13 PM
The Sphinx
Champion City
Because the 318 in question is already built.
Re: MPG 318 VS 360
[Re: The Sphinx]
#837396
10/25/10 03:19 PM
10/25/10 03:19 PM
patrick
Grand Haven, MI
I'd at least swap the cam to a lunati voodoo 60400, and the carb to a 4bbl w/a 600 eddie or a small q-jet/tquad...
