What's the point of valve lash ? #836904
10/23/10 08:44 PM
10/23/10 08:44 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
What's the purpose of valve lash? I could understand setting a cold clearance if the gap closed up at operating temp but it doesn't, the gap increases. So why not "zero" lash cold ?? Seems to me that leaving a gap like that just subjects the various valvetrain components to an unnecessary hammering.
Re: What's the point of valve lash ? [Re: Stanton] #836905
10/23/10 09:16 PM
10/23/10 09:16 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
a tolerance to accommodate wear on the valve train ?
You could close it up if you are running the valves every lap and probably be O.K. .............or not.
Re: What's the point of valve lash ? [Re: Stanton] #836906
10/23/10 09:22 PM
10/23/10 09:22 PM
gregsdart Offline
gregsdart  Offline
A zero lash cam would have to much duration for best results. The valves would open too slow, and close too slow, allowing intake charge to escape or exhaust to escape too early and cut down on power. Thats why solid cams offer a bit more power than hydraulics, and roller cams are better yet. The best scenario would be instant open/instant close on the valves, but that isn't possible. Yet.
Re: What's the point of valve lash ? [Re: tubtar] #836907
10/23/10 09:26 PM
10/23/10 09:26 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Valve lash is the clearance in the valve train between all the valve train parts to allow the full valve opening and also to make sure it closes all the way
home of the
Sox and Martin Hemi Duster
Re: What's the point of valve lash ? [Re: HEMIFRED] #836908
10/23/10 09:30 PM
10/23/10 09:30 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
We run tight lash cams in the street cars and boat stuff. .010, You need some or with the engine temp change it will hang the valves open.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What's the point of valve lash ? [Re: gregsdart] #836909
10/23/10 10:33 PM
10/23/10 10:33 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Actually it is "possible". A buddy of mine in the R+D biz says Honda has an engine with no cam that uses an ECM and solenoids or stepper motors to open/close the valves. Think of the possibilities, infinite cam timing changes on the fly so it can idle like a stocker and pull like a prostocker on the topside and everything in between. The wonders of modern technology .
I can't even imagine the $$$$.
Kevin
Re: What's the point of valve lash ? [Re: Twostick] #836910
10/23/10 11:43 PM
10/23/10 11:43 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Its possible but not desireable.
Keep in mind that the intake valve starts to open before the piston is at TDC and the exhaust valve is still open after TDC. A valve that opened instantly would spell disaster.
You could argue that that's a flaw with current technology HOWEVER, the overlap is a necessity in a normally aspirated motor as it is the exhaust flow that gets the intake charge moving. Remember, the exhaust is under pressure but the intake relies on atmosperic pressure to fill the cylinder.
Re: What's the point of valve lash ? [Re: gregsdart] #836911
10/23/10 11:57 PM
10/23/10 11:57 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Not true. All cam specs are based on the actual lobe, not the "after lash" measurement. Subsequently a .600" lift cam with .020" lash will only yeild .580" lift.
And more to your point, if lash is .020 then whatever the .050 duration spec is remains unchanged at the valve since the lash is already taken up before the .050 point. Only the "advertised" duration would be less at the valve after the lash adjustment.
Re: What's the point of valve lash ? [Re: Stanton] #836912
10/24/10 12:19 AM
10/24/10 12:19 AM
IN
ahy Offline
ahy  Offline
IN
Why lash? Its really bad if a valve doesn't close all the way. Hot high pressure gas flowing over the valve during the combustion stoke will quickly trash it. Lash provides some safety margin to cover thermal changes and recession of the valve into the head to make sure the valve closes all the way.
Re: What's the point of valve lash ? [Re: Stanton] #836913
10/24/10 12:20 AM
10/24/10 12:20 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Tolerance and compression issues for the components under load. At running conditions the clearances will go away at times. If there is not enough lash things like valves hanging open can occur. My2cnts.
Damon
Re: What's the point of valve lash ? [Re: Twostick] #836914
10/24/10 01:07 AM
10/24/10 01:07 AM
New York
polyspheric Offline
polyspheric  Offline
New York
You'll know when that happens: all the parts break the first time.
Boffin Emeritus
Re: What's the point of valve lash ? [Re: polyspheric] #836915
10/24/10 05:26 AM
10/24/10 05:26 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
WHAT?THATS IT?THATS ALL? ARE YOU ILL?
Re: What's the point of valve lash ? [Re: bonefish] #836916
10/24/10 05:29 AM
10/24/10 05:29 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Great! another moparts theory thread
Mopar Performance
Re: What's the point of valve lash ? [Re: Twostick] #836917
10/24/10 05:36 AM
10/24/10 05:36 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Kevin
I've thought about that before! fully variable valve timing and lift! solenoids to open/close the valves. you could write a computer program to optimize power/torque at ANY rpm/throttle setting, or, fully shut down cylinders on the highway by just hanging the exhaust valve open so there's no power loss by a piston sucking down on a closed chamber, or pushing up on an empty one, yet not allow raw O2/gas to get sucked past the intake...
i wonder what a set-up like that would look like, and how much it would cost!
sure it sounds great, but then you'd lose that "high power lope" at idle that a radical high RPM cam gives you...it'd idle dead smooth with minimal overlap/duration at idle, yet hang them open as long as possible at higher RPMs for that top fueler scream.
**Photobucket sucks**
Re: [Re: 70Cuda383] #836918
10/24/10 06:10 AM
10/24/10 06:10 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
did we answer this? or did it get hi jacked
home of the
Re: [Re: HEMIFRED] #836919
10/24/10 06:15 AM
10/24/10 06:15 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yes
seems the answer is that nobody knows exactly why, other than 'insurance' to keep parts from breaking, and to allow the valves to "snap" open and closed.
Re: [Re: 70Cuda383] #836920
10/24/10 10:15 AM
10/24/10 10:15 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Why dont you zero lash your solid cam....fire it up. Rev it to 6500 a few times and take it to the track or street and report back to us....? By the way, there are several good parts suppliers on this site that will be able to help you AFTER the "run-in".
Re: [Re: 70Cuda383] #836921
10/24/10 11:01 AM
10/24/10 11:01 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Yes
no this is the answer in a condensed version
all done as above is your reason
home of the
Re: [Re: HEMIFRED] #836922
10/24/10 11:07 AM
10/24/10 11:07 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Just guessing here, since I don't work for a valvetrain manufacturer, but allowing for the valve to fully seat on the head and cool is part of it, along with allowing oil into each point of contact bewteen parts.
Re: [Re: HEMIFRED] #836923
10/24/10 11:13 AM
10/24/10 11:13 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i am gonna put my two cents in..
Valve lash is needed because of harmonics..
Ever struck a bell or plucked a guitar string?
same thing happens to the components in the valve train..
at high rpm everything looks like a wet noodle.
valve lash compensates for parts growing and or recoil..type effect..(equal and opposite reaction)
As to the selinoid valve operation..
its been designed and implemented for many yrs..
mosty in Diesel motors ...because they run at lower rpm..
the biggest draw back to the selinoid system is
rpm or duty cycle..the technology isnt there yet to open and close them at high rates
that is the issue with this tech that is problematic..and also why you will find them now only on diesel motors.
ive always said..use two intake valves and alternate which one opens. this would split the duty cycle in half.
that should atleast double the rpm range.
but i digress
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
