oil pump pressure increase #836790
10/23/10 03:14 PM
10/23/10 03:14 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
got a old 360 we are gonna put in a plow truck,gonna put in a new oil pump and timing chain,i want to increase the pump pressure by putting a washer ,etc behind the spring,i see it has a cotter key holding what looks like a soft plug in,will the plug come out easy once the cotter key ois removed,or is there a trick to getting it out and back in without ruining it?
thanks in advance!
Re: oil pump pressure increase [Re: rhad] #836791
10/23/10 03:26 PM
10/23/10 03:26 PM
cant save it as it's pressed in tight & no way to get it out. Drill a hole then thread in a screw and slide hammer or lever it out/add washer/press in another mini plug from your parts house
Re: oil pump pressure increase [Re: rhad] #836792
10/23/10 03:47 PM
10/23/10 03:47 PM
Kirkland, Washington
Pacnorthcuda Offline
thanks in advance!
If you do that all you will do is increase the pressure RELEASE point--I.E. cold start and max rpm pressures. Your mod will do nothing to increase moderate RPM/hot oil pressure. Just in case that was your goal. It would take a high volume pump or heavier weight oil to do that. (Or of course tighter engine clearances)
Re: oil pump pressure increase [Re: RapidRobert] #836793
10/23/10 03:48 PM
10/23/10 03:48 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
thanks!
seems as tho ive done this before but my memory is fuzzy at best on this
